bundy, I really liked the red much better. You had the whole thing really fine tuned, it's JMO but, you de-tuned your rig a bit.
I took it of the stand and mounted it on the out side of one of the legs.
Than I bend it over. I ziptied it to the other leg for some extra support (not really needed)
The screws on the outside are not used, just put them there so I don't lose them.
http://robbakker.com/cmt01/images/T01wc033pump.jpg
Looks like clear tubing to me.
Nice rig though, awsome cable management.
I can never be bothered much with that sort of thing.
when I do bother with tidying up, I just move the mess
to behind the motherboard tray.
Neat looking rig !
Impeccable cable management :up:
@Waterlogged: Dude, the red/white thing was nice, but..ya know....i got this setup for over 1 year, so its time for some new HW and colors (HW Update with dfi board soon, when mips send me the waterblocks) and btw: the main theme was copied too often from many users in my home forum until now :D (i got more than 50 pn´s about the water mixture :) )
There is an older estimator that I have attached that should have your stuff. As far as you question, here is the response from Alex Venz gave me when I asked pretty much the same thing.
"People have had mixed results with that approach... Putting two radiators into a system can improve performance beyond that of a single 3-fan radiator, provided that the added pressure drop (and, thus, lower coolant flowrate) doesn't negate the performance gain from the added surface area. Since you're using a DDC-3.1, I think that the flowrate difference would be pretty minimal so, if you have room, a second double fan radiator may be a better solution.
Best regards,
Alex Venz
Co-Owner, Petra'sTech/Petra's Tech Shop"
They though a lot more about this than I do. I hope this helps.
Utnorris
CraptacularOne, looks really good, I'm jealous. And Bundymania, love the orange look, I am big Tennessee fan, so the orange coloring is definitely a plus in my book. Love this thread,
Utnorris
Thanks for the kind words guys :up: took a good while to finally get all the cables hidden the way I wanted them. The tubing is clear, it's the coolant additive that is gives it it's green color. It's also UV reactive so I'm planning on also putting a UV light on the bottom to really make the green tubes jump out. :)
New cam, new pic :)
LEDs installed finally.
http://www.lifepatcher.com/pc/ll/open.jpg
nice!!! what cam?
Canon EOS 350D (DSLR)
My dad went to buy the new 450D so I got his old cam 350D
Well, I didn´t get it as a present though. Christmas in advance or how can I say? :D
i got my uv lights put in now. the wire management could be better but it was all i could do without a bunch more mobo tray cutting. maybe in the future i'll fix it up, but for now i'm very pleased with the results.
http://img517.imageshack.us/img517/7...re18736jp3.jpg
By rangerone7669, shot with Photosmart M415 at 2008-05-08
That would take 10 minutes with Corel Draw/CAD/ and a laser cutter ;) Nice job by hand tho
laser is teh bomb:
http://img509.imageshack.us/img509/4025/dd3tt7.th.jpghttp://img255.imageshack.us/img255/4...0325xo7.th.jpghttp://img85.imageshack.us/img85/721...0298gh0.th.jpghttp://img168.imageshack.us/img168/2...0297kr2.th.jpg
Dude I cannot image the havok you would subject the world to if you have this type of equipment and your design skills
via dremel is more fun...lasercut need no skills ;)
i know some local companies, where i can made lasercuts for $$$, but its not "real" modding in my opinion - handmade rocks :D
http://www.abload.de/thumb/img_200448v.jpg
^^thats awesome dude!! :up:
Gee, wish I had a laser cutter just laying around, :D.
utnorris
handmade rocks but laser rocks too :D
http://img241.imageshack.us/img241/4999/x3zx8qi0.th.jpg http://img241.imageshack.us/img241/6...8ml1od5.th.jpg
Is that a poster of a Lamborghini in space?
yes, i hate it. Its only there to cover up a hole i need to fix :rofl:
