Thanks for all the advice
Originally Posted by
smee
The reason your temps are high is because having smaller tubing will make the pump push the water through really fast, water going TOO fast by the copper on the waterblock CAN create heat.
Am using 7/16 tygon tubing and my pump is much stronger than the D5 at 18v.
You should look into getting chipset blocks like the
MCW30's or some
EK's, and maybe some
7/16" ID tubing.
You've got quality components in your rig, but you can cool it better with an air cooler compared to some of the watercooling gear you've got in there now.
I donīt think any air setup will handle a B3 at 3.4Ghz better i feel the problem might be my rad.
I think your doing a great job improving on this build, some here might not like some of the things you've got.
But what really matters is if YOU like it and that it WORKS. :up:
Thanks pal :up:
Shocker, I like but...I think you need to remove those restrictive Alphacool blocks. I think that's your biggest problem now, that and maybe 12/10 tubing next time, 8mm I.D. is still a bit small.
Maybe i will change them in future becos of looks, but they are doing their jobs well. My chipsets 9°c above room temp when my cpu is idle.
taylormsj
The only thing i dont like are the fan grills, the rest looks good, im not sure about your temperatures, what are you room temps, what fans are you using, and i dont know much about your pump, is it powerfull enough?
My core 0 is always 15°c above the room temp and core 1 and 3 are equally 11°c above the room temp too(idle). 100% load they can reach 56°c for the hottest core with room temp at 25°c. As for the fan grill i had to install them becos, i once got a cut on my finger from the exhaust fan. I use three silverstone FM 121 fans on my rad. I dont know if the rad can really handle the heat from all the hardware in my loop. Am thinking of adding a Swiftech MCR220 240mm Radiator to my loop, but i donīt know if it will help.:confused:
