my build... latest update with DFI Lanparty UT-P35 T2R..
http://i228.photobucket.com/albums/e...n/DSC01532.jpg
lichyetan, that looks SICK!!!!!! :shocked: :shocked:
More pics, MORE PICS!!!!!!!!!!!!!!!!!!!!!! :D :D
Haha nice. x48 ^^
my rig in video clip:
YouTube - IOPANEL - KIBUB'S RIG- WATER COOLING
the track is infected mashrum :)
Hey guys, just thought I'd show you fellows my new rig I've built (specs in sig)
http://xs227.xs.to/xs227/08184/side142.jpg
http://xs227.xs.to/xs227/08184/dark991.jpg
http://xs227.xs.to/xs227/08184/front826.jpg
Don't mind the phase change unit under it ;)
hello fellas, im a noob watercooler......actually this is my first real build using different components. i have duel black ice extremes, a danger den cpu block, and a ek northbridge block for my set-up. the video is just aircooled. still have to install top and side covers......ther at my friends gettin some lazer engraving. will post update when its all completed. i have the q6600 quad running @ 3.6ghz. peace, randy.
After many months of reading on XS, here's my baby.
Desk:
http://mattls.com/newcase/desk.jpg
With side on:
http://mattls.com/newcase/Inside4.jpg
http://mattls.com/newcase/inside5.jpg
Side off
http://mattls.com/newcase/Inside3.jpg
http://mattls.com/newcase/inside7.jpg
GFX
http://mattls.com/newcase/gfx.jpg
Northbridge cooling, mounting idea stolen from Deanzo :P
http://mattls.com/newcase/nb.jpg
Rads in the bottom. Its a really tight fit, a 360mm on one side and a 240mm on the other side, but I made it fit.
http://mattls.com/newcase/Rad.jpg
http://mattls.com/newcase/radclose.jpg
Needs a bit of cable tidying, but I just wanted to get in and play games, so it'll have to wait :P
So many nice rigs here :eek:
This is my first WC rig and I seriously made lots of mistakes. I'm going to repaint the case, redo the whole WC setup, add 8800GT to loop and mount rad inside the case. Maybe even get rid of res and add T fitting. I would be very glad if someone would point out what is wrong in my WC setup so I don't made same mistakes again. I mean really point out everything what is wrong, don't hesitate, make me cry, its all good. Ofcourse you cannot see pump which is hidden in 5.25" slots. Don't have any pics of that, but I think no-one even wants to see it :)
Going to take more pics when I have done everything right :)
So, those pics:
http://mbnet.fi/natech/Untitled-1.jpg
http://mbnet.fi/natech/Untitled-2.jpg
http://mbnet.fi/natech/Untitled-3.jpg
And sorry for my bad english hope someone understood what I meant.
very clean = very nice
thats mine also...before it is broken again...this is the first of the two broken P5e......
http://img523.imageshack.us/img523/960/dsc04067ip1.jpg
Blergh Thermaltake waterblock :shakes:
Hahaha TT waterblock. Btw, your revised build looks great. Nice and tidy ^^
I lost an MSI P35 board and an 8800 GT to a leaking thermaltake rad..... That was when the GTs first came out and were about 310. But now I'm on quality watercooling and have nad no more incidents :)
Hi Guys!
My 2-loops wc Lian-Li V2100 :
http://img254.imageshack.us/img254/2...e071zg2.th.jpg
But i need 3x 100cm sata uv cables :(
On screenshots of the screen like it is visible...
Q6600@3200мгц 400*8 1.26875v, Asus Maximus Fomula, 2*2048 OCZ Reaper + 2*2048 OCZ Reaper X HPC, Gygabyte-8800Ultra@702/1782/1080 , Armor,
2*raptor 150 + 750 seagate. 3D mark 2006 ~15000 (Vista 64)
1. EK Water Blocks EK-Supreme Acetal
2. promodz south bridge 2.1. promodz north bridge
3. EK 8800GTX/Ultra
4. Laing DC-1
5. Watercool MO-RA 2 + 4 120mm fan 1000 rpm
In the pic above. When you redo the loop make sure you change the intake of the CPU block to the bottom. You want the water flowing in from the bottom to the top to eliminate any possibility of their being bubbles at the top of the CPU block.
Other than that, nice looking rig and good cable management :up:
change my barbs to 8mm for better flow and repainted my case.
New pix included...
Hi guys, i've been watching this thread for months,now i can reply:)
here's my system:
built a little waterstation in a crappy old minitower..
http://www.pctunerup.com/up/results/...7_DSCN0707.JPG
http://www.pctunerup.com/up/results/...7_DSCN0696.JPG
here is on my lian li:
http://www.pctunerup.com/up/results/...3_DSCN0699.JPG
http://www.pctunerup.com/up/results/...0_DSCN0700.JPG
now let's look inside the pc:
http://www.pctunerup.com/up/results/...4_DSCN0708.JPG
blocks are D-tek fuzion with 4,5mm nozzle and thermalright backplate,on the gt a Ybris K7
http://www.pctunerup.com/up/results/...2_DSCN0710.JPG
http://www.pctunerup.com/up/results/...4_DSCN0711.JPG
and here's a shot by night:cool:
http://www.pctunerup.com/up/results/...6_DSCN0709.JPG
Still work to do..I have to finish the painting of the ws and fix all the mess of cables..
hope you enjoy:D
What is the GPU block?
it's an italian block called Ybris K7
more info here: http://www.ybris-cooling.it/product_...95e6b4ceea1db7
