still nobody?Quote:
Originally Posted by KamE38
still nobody?Quote:
i think there are some guys with that stepping on http://www.hardforum.com/showthread....highlight=0546
Well, it's brand spanking new....try it out and fill us in.
@Vapor
i'm still waiting 4 UPS atm... :slobber:
@arctic-k20
THX a lot
Heh...Quote:
Originally Posted by Jeff
Well got mine dual prime stable with stock heatsink and stock voltage easily up to 2.6ghz. 2.65ghz at stock volt was no go so now I am going on the other extreme to burn it in. Burning it in at 1.1375 2.24ghz or so for one of the cores to straighten up it's act. Going to be long while before I can post phasechange result with this one considering how many more voltage steps I've got ahead.
Nope, Vapo is in the closet. I'm using the stock heatsink that came with the cpu. I was able to get it to 2.65Ghz using 1.55 Vcore. I'm priming right now. I wasn't able to get 2.7Ghz stable going all the way up to 1.6Vcore. Higher will have to wait on phase. What kind of difference in temps is the TT Big Typhoon making compared to the stock sink? My room temp here is about 27C maybe a tad higher. Sunny Florida.Quote:
Originally Posted by phadeout
Any info on the 170 CCBWE 0544XPMW? Going to buy it tommorow. From what I found looks like a good buy, but you never know.
Yeah, read back in the thread, there is one fully tested here... I think it was Eva2000, but could be wrong.Quote:
Originally Posted by bestmancajun
Anyone know what steppings Monarch or Newegg is currently sending out. I was thinking of picking up another combo with a cheap MB and move this processor down to a encoder box. Probally gonna get a 170 or a 175
Originally Posted by cdelatte
Im waiting till your auction is complete think I have decided to try to get another 170 for my system. I really want 2.6+
hi @ all!
does anybody know an opteron 165 with this stepping CCBWE 0534 MPMW?
thx
Wow! you did 30 hours of burning, i need to get some more burning then, I am 15 hours now I think, but if I can get voltage that low, that rocks!:banana:Quote:
Originally Posted by krjalone
Tip: it seems that raising the LDT Voltage from 1.2 to 1.3 Volts is required to make my 175 quoted above stable at 2695 MHz at 1.6 Vcore.
Yesterday I got back to 1.2 and it failed prime within minutes. Since then it is dual-priming happily with 1.3.
my 170 is currently stable at 270x10 with 1.375+113%
currently testing at 275x10 , ~45C while dual priming
and hopefully 280x10 to follow
What's your stepping ripken?Quote:
Originally Posted by ripken204
My Opty 165 is looking good so far. I'm still burning it in.
Summary of results:
2.58GHz @1.33V (stock, as reported by DFI BIOS)
Burning in at 2.6V 1.325 x 104% = 1.378 V. I should have stayed below 1.36V before trying this. :stick:
I'll be updating my progress here:-
http://www.ocforums.com/showthread.php?t=428946
Stepping is:
CCBWE 0534 MPMW 131606AK50026
Any info/suggestions on this one guys?
@Fluence-i dont know, i took a pic of it but the flash on the camera just got reflected right back and you cant make out anything, and i hadnt realised that at the moment. ive tried to take my heatsink off but i have no clue how to, ive tried and its just impossible
guys.. just a quick question..
how does the 170 does nowadays.. like the one in monarch now ? i really do feel like getting a dualcore that can do 2.8Ghz..... my 165 is now running at 2.7Ghz.. but it isn't maxing out my RAM.... i need something that can go above 2.75Ghz...
My suggesiton, be happy with what you got. that 50mhz won't make you feel much better really after you look at how much money you spent swapping things in and out. If you do get 50mhz.Quote:
Originally Posted by harpyboy
hahaha.. i can't disagree with that..Quote:
Originally Posted by jinu117
but since the opteron series are getting phased out... i don't really feel at ease without having the best with me ... im pretty sure most feel the same as well... :rolleyes:
Heh... it's just from experience... wouldn't have snatched my optie if my x2 3800+ didn't die really. Think in retrospect though, if you get better cooling than what you have now, maybe that optie is 3.1ghz chip... maybe 3.2ghz chip. Maybe something that was awesome under water or air just don't like phase... many things to think about. At the end, unless you are bench maniac, 50mhz doesn't really make much difference :) Want better cooling such as phase change (devilish grin on side)? I see you are local to me.... come come.... :)Quote:
--> slaps self hard...
Ok... back to my better side... okay, so... stick to what you have and maybe look for used market vigilantly. I am pretty sure someone will get bored of their optie soon enough :)
true that man i had that 0530 CABNE 146 optie and it ran like crap under phasechange put that sucker on air and 3gigs was np at all....
peace perc,
haha.. alright... i guess i should be happy with my 2.7Ghz dualcore after all
Glide dental floss :D
Started to work it between HSF and IHS when I was done w/ init testing under they popped apart :fact:
260x10 1.45v 1:1 3-4-3-7
its been dual priming for about an hour, ill let it go till the morning and report back, if its stable then this is prolly where ill stay.
i dont want to mess with watercooling or phase change. dont have anymore money after buying this rig.
