The Sapphire GTO2 should be unlockable, so far i have not heardQuote:
Originally Posted by Millyons
of one that can't be unlocked.
I'm also interested if those 50 were all C3D r423 and/or 2ns parts...
ye, sadly, they are. :(Quote:
Originally Posted by Heretic
which bios is best for sapphire gto2?
i use stock 16p, but it clocks not so good, i cant get stable >600, and it's not loopstable in 01mark, get freezed after 3-4 hours
use TIN TIN bios its little bit beter i think http://simon.webideal.ca/X800GTO2/TinTin.bin
or this bios
http://simon.webideal.ca/X800GTO2/sx850pe.bin
it seems thate a X800GTO² can handel more VGPU thane a X850
http://i3.photobucket.com/albums/y90...ipper/vGPU.jpg
1.838VGPU:fact:
max VGPU without ovp , it gone come on water aimin 700mhz core ;) .
so far on air 1.79VGPU have 657mhz core 3D stabel and 645mhz withe memtweak :D .
happy banching
Is water in roomtemperature or colder?.That's quite high voltage :slobber:Quote:
Originally Posted by blind_ripper
watertemps dont know the room temps where round 10°c Ã:banana: 7°c .
thx next week or so il heb DD maze4 and the card wil go on chiller later on ;)
Are you sure?
http://www.xtremesystems.org/forums/...&postcount=541
Try it with that, eh?:fact:
im almost sure, seems that all newer cards are unlockable, LOL man u got my hopes up, but if the Fs don't match there is no help, LOL im trying to tell myself that when they get here they wont be able to mod (witch they 99% wont be) so im not so disapointed, there is still a flicker of hope in me that i got to suppres withnin next couple days LOL, i guess ill just got to spend more money and get a 7800GT
My gto² under watercooling... I m going to test it with more vgpu ,
vdd mod and cold water ..
But for this test :
VGPU 1.7v
VDD Stock
Watercooling water ~ 22° GPU + CPU
http://users.skynet.be/pt1t/x800/8029.PNG
http://service.futuremark.com/compare?3dm05=1526326
nice score pt1t check my score a kopple of post back , whates ur name on tn ? il get u in a week or so ;)
does anyone know how to change the vivo on the c3d to pal from ntsc?
How much volts did You put on gpu with zalman vf700cu ??:)
1.79vgpu withe zalman vf700alcu
:D
1.79vgpu withe zalman vf700alcu :O
with the Open windows cooling IMO :)
There should be a DIP switch near the fan connector.Quote:
Originally Posted by aaron_sue
I've read the instructions for vmodding X850 cards. I only want to perform a vgpu mod to roughly 1.4-1.5v depending on the overclock. I'm currently sitting at 594/621 but want to run at least 610 on the core. Does anyone have a completed picture of how a modded vgpu X800GTO² looks like? I understand your image won't be 1.4-1.5v....but I just want to see a picture before proceeding with the mod.
http://users.skynet.be/pt1t//x800/gto2sl2_001.jpgQuote:
Originally Posted by Pt1t
My card :p
well just like i thaught got my 2 connect3d cards today and they are both unlockable :(
You used flashrom16p? The standard flashrom app won't do it.Quote:
It's a major bummer if the new cards are unlockable :(
This is on Nintek in Australia:
http://www.nintek.com.au/x/scripts/p...idproduct=4326
Any of you had these before?
(Powercolor X800GTO 16 Pipes)
