Being Stable in Games is the big thing for me too, I can run much higher but if it does not stay stable in games at a ubber high setting it does me no good :D But i think where you are sitting now is pretty damn good.
http://www.dmp-racing.com/king/compu..._overclock.jpg
I will try for more later.
Finally got some in the UK Here
Mines finally on its way:banana:
Just got 2nd pair of 2GB EB kit from newegg. The times on the sticks reads 3-4-3-8. Is it suppose to be 3-3-2-8?
Anyway, the SPD timings reads 3-3-2-8. Maybe mislabed? :(
Edit: stable at 2.6v 3-3-2-8 @ 255MHz. Havn't try higher.
We had some sticks go out with the stickers wrong. No worries if they are stable there from the sounds of it :)Quote:
Originally Posted by bobov
I'm not worry now. :)Quote:
Originally Posted by RyderOCZ
Seems 3D stable at 2.6v 3-3-2-8 @ 265MHz. 270MHz unstable.Quote:
Exactly same as my first 2GB EB set which I brought a month ago. :)
Sounds like another good kit there. Enjoy them.Quote:
Thats about where mine are also though not completely stable at 265 yet. I can bench 3D with them at 2.6v using the same Opty 148. I do get some errors on memtest 4 and 5 though. Still working on it.
Which motherboard was used for these settings....I hope it was a DFI Expert.Quote:
Originally Posted by eva2000
So
my settings on the expert :)
http://www.forumdeluxx.de/gallery/da...B-275_long.jpg
I hope 280 works too
WOW :eek:Quote:
Originally Posted by t-bone
Show us some 3D benchmark screens please. :)Quote:
T-Bone,Quote:
Great overclocking! Would you mind sending me your BIOS settings, so I can compare to mine. I can only get 265 stable.
Im using the Ultra D and so far 265 seems to be it also, though you have a few different settings then Im running.
@sweeper:
DRAM Frequency Set............................ - 200=RAM/FSB:01/01
Command Per Clock (CPC)....................... - Enable
CAS Latency Control (Tcl)..................... - 3.0
RAS# to CAS# delay (Trcd)..................... - 03 Bus Clocks
Min RAS# active time (Tras)................... - 08 Bus Clocks
Row precharge time (Trp)...................... - 02 Bus Clocks
Row Cycle time (Trc).......................... - 7 Bus Clocks
Row refresh cyc time (Trfc)................... - 13 Bus Clocks
Row to Row delay (Trrd)....................... - 02 Bus Clocks
Write recovery time (Twr)..................... - 02 Bus Clocks
Write to Read delay (Twtr).................... - 02 Bus Clocks
Read to Write delay (Trtw).................... - 03 Bus Clocks
Refresh Period (Tref)......................... - 4708
DRAM Bank Interleave.......................... - Enabled
DQS Skew Control.............................. - Auto
DQS Skew Value................................ - 0
DRAM Drive Strength........................... - Level 8
DRAM Data Drive Strength...................... - Level 2
Max Async Latency............................. - Auto
DRAM Response Time............................ - Fast
Read Preamble Time............................ - Auto
IdleCycle Limit............................... - 016 Cycles
Dynamic Counter............................... - Disable
R/W Queue Bypass.............................. - 16 x
Bypass Max.................................... - 07 x
32 Byte Granularity........................... - Disable(4 Bursts)
so here the benchmark-screen :)
http://www.forumdeluxx.de/gallery/da...0173for_xs.jpg
What is the limit on that 148, mine was doing 3025 at 1.42v before the Crucial meltdown 24/7 and would do 3100-3200 on water. Now Im sitting at 2926 with this EB. I need to figure out this occassional reboot issue that showed up with this new OCZ ram.
:clap: Thank you. nice nice.Quote:
My EB kit seems let me OC my 148 to 3.0GHz at lower vcore than ballistix.Quote:
Originally Posted by flesheatinvirus
I buy two sets of this moduls..ı am very disapointed with them.:confused: .firstly ı try first kit and it cannot be stable in 3d with 250 3-3-2-8 and then try second kit ı suprised it is not stable again in 250 with 3d..so I try all of the modüus with single and choose the best moduls..At this time only 250 3d stable 251 not go...:slapass:.ı try all bioses and settings but they hane't been any ipmovement..
I am very dissapointed:nono: the best set only goes 2d 258 and 3d 250:slapass:..İt is not cpu issue ı try 165 530tpmw 170 550upmw and opty 146 540apmw
Sorry to hear that. Could you provide us more details of your system spec & BIOS settings. Both of my sets can do 265MHz 3D stable. Maybe sth wrong in you settings?
Dfi sli Dr(AA0)Quote:
opty 165 530tpmw&170 550upmw&146 540apmw
asus 7800gtx256 sli
4x120 samsung sata2 raid0
enermax 660w and etc....
ı try 704-2bta&623-3&510&310&310p and etc.. all of the bios maybe all ram tweaking settings but not any improvement..ı asked via pm to ocz guys they offer me 704/2bta and
(1:1) 1T 3-3-2-8 10-16-2-2-1-3-A-1-E-A-3072-6-3-8-N-6-256-D-16-7-D ı try a lot of settings but windows cannot boot over 260 and not 3d stable over 250 with good sticks:nono:
What voltages were you using with those?
http://tony.i4memory.com/eXpert/2.3vdimm250.JPG
If you have eXpert, venus, or RDX200 you may want to try undervolting the dimms, i maxed these out at 268fsb 2.5V but prefere the 250 shot here at 2.3V or so....note the timings, i doubt you would see tighter apart from cas2.5 maybe.
Ohh and i never set the correct time and date on test rigs...i did this 18th feb 2006 ;)
İf you asked me ı try 2.5-2.6-2.7-2.8 ı haven't got expert so only try these and +0.03 settings to applly them...Today I rmaed all the sticks to local retailer..Quote:
Originally Posted by ahmad
