This pump Laing 12V DDC1+ Ultra 18W (http://www.watercoolingshop.com/cata...roducts_id=614) It's the same that MCP355 or DDC3.2??
Thanks!!
Thanks!!
You mean THIS one?
Yes.
for a sticky with the topic: "Choosing The Best Pump for Your WaterCooling System" it certainly doesn't help in choosing a pump, it only lists a few pumps and writes a few sentences on them
Actually, the recommendations in the very beginning of the OP is quite useful. It's how I chose my MCP655. The decision will always come down to your budget, and your needs. If you know those, listing the characteristics of these pumps should help you in "Choosing The Best Pump for Your WaterCooling System."
-bZj
The sticky is great. If there was a perfect pump, than no need for competition. As pointed by down8, each pump can be a perfect match depending on your needs.
But, hey, you can add a clean post where you gather and synthesize all the info instead of posting everywhere that the stickies don't suite your flavour ;)
Don't take it bad or personal, but instead of criticizing, try to contribute. Just my two cents :welcome:
the topic's subject is "Choosing The Best Pump for Your WaterCooling System"
it doesn't explain how to choose a pump but instead just gives a few descriptions on them
Oh yes, the article can't choose it for you right? The descriptions should let you make your choice yourself.
Just think at it as there's not a best of all pump. But yes, there's a "BEST Pump for YOUR WaterCooling System".
If you still can't make a choice, just open a topic in the "Liquid Cooling" area. Hopefully some kind people would help you understand why get a pump and not another one for your specific situation
same thing as in choosing a computer only you can give guidelines like: if you don't buy the computer for gaming don't invest in a good HD. if you plan to save a lot of video or HD images get a big HD. if you're worried about your data do a raid
Sorry to be rude, but if you find the stickies useless, then go look elsewhere or write us some good ones. Go ask your dad to pay you a private consultant that can choose for you a pump since you seem unable to make any decision by yourself :shrug:
My last answer to you (another stubborn on the ignore list).
PS: when you answer others' posts, take the time to read and think before writing useless answers (in regard to some of your posts in other topics, heh)
My swiftech 350 burned out today. I'm going to get an iwaki, but I don't know what to do about the barb sizes. I have a 3/8" loop, but I'm looking at the 20RLT and that uses 3/4" hose hookups. How do I convert, and can I go so low as 3/8" without causing the pump to stop functioning? I could also get a 30RLT or 40RLT at the store I'm going to, but they cost more. Would it be worth the extra money to get these pumps over the 20RLT?
I also don't have a res. does a pump this big need one to keep the pressure manageable?
Those pump models have NPT threaded connections not hose barbs, you can easily get the correct adapter from McMaster.
More information on (W)MD Pumps
Can you please update the sticky, It was last updated over a year ago..
From reading it, I decided to get the Eheim 1250
but on further research I found there have been more pumps and Eheims put on the market since the update
Which one do I get... :shrug:
Of course I want to spend the least amount of money but I also want a good pump for a triple rad, dual rad, and possibly a single rad all in 1 loop
Does anything beat the Eheim 1250 in price for power?
Either DDC3.2 or Laing D5, also worth considering having two in series.
Hi guys, can you help me with this ?
i started to build a wc system and in my country the only cheap pump that i can get is one called Atman but i have2 models in my mind.
Atman 103 - 1000 L/h - elevation 1.2m apox - 25w - Wide: 9,5 cm - High: 8 cm - Deep: 6 cm
Atman 104 - 1800 L/h - elevation 2m aprox - 38w - Wide: 11 cm - High: 8,5 cm - Deep: 7,5 cm
Both of them work under water and the 104 its a little bit bigger in size.
I will use only a block for my cpu and a rad for 2 120mm fan.
1.2 meters = 3.9 feet
2 meters = 6.5 feet
1000 liters = 264.1 US gallons
1800 liters = 475.5 US gallons
10 centimeters = 3.9 inch
I'm no expert, but the specs on either pump are sufficient for a reasonable setup. If you want someone to give you a more specific answer, you're going to need to post what you plan on putting in your loop.
Or just use martin's flow rate estimator (http://www.martinsliquidlab.com/Mart...Estimator.html) and pick a pump with similar specs to those.
Of course, unless someone has direct experience with those pumps, it's up in the air as to how loud or reliable they are.
Both pumps will give you a great flow on a low restriction setup. They are not suited for high pressure drop WB like the EK supreme which will kill them for sure.
Even a GTZ or a Storm should work fine. They are pumps like Eheim 1048-1056-1060 series
You could even add some low restriction NB and GPU WB like a MCW30 or MCW60 if you like
Also keep with 7/16 or 1/2 id tubing and low restriction radiators like the TFC, PA and MCR series
how can i know if any of those model work on a jet block ?
Can you please recommend me a good pump for a 9.120 MoRa radiator? Tubing will be 1/2 or slightly smaller.
