just received my A8V Deluxe and FX-53...
here is the serial : **MG0J27098
please tell me it's good...
my FX-53 is a week 22
Ok, here's a new one 45MG0L0153 Rev 1.02
What are the "J" board rev #'s?
Revision 1.02 :D
Well at least the "L" comes after "J" so I hope the locks work on this one too.
The NB is an 0419CD
that sounds like REALLY new gear, g/l!!!!!!!!!!!1Quote:
C
xgman,Quote:
Sounds like you have got a REAL NEW board. Load her up with 1005.021 and see how she does! G/L!!!!!!!!!!!!!!!!!
C
I'm gonna try a modded 1006 bios with locks re-enabled.
Sounds good! Will be anxious to hear how that BIOS is....where did you find it?Quote:
C
Charlie, what did you use to rip the Vcore R167 off of the board and how hard was it to come off?
Tony did it and said if it works for me then he'll post it.Quote:
C
Pretty easy. I used a fine tip 25w iron and solder braid. I went from left side to right side and back to left side, and kind of wiggles the iron when the solder started to get sucked up and the SMD didn't stick to pad very well and it just "popped" off, 20 seconds tops.Quote:
C
what is sodder braid? Do they have it at radio shack?
Yes, they sell it at radios shack. Probaby better to get some finer braid at a electronics shop though. Its usually braided copper and its also known as solder wick. Its used to remove solder from components
Beginning to think that there are two very different mobos.
My mobo from EU has 1 RED IDE and 2 RED sata, where Charlies attached picture on first site has BLACK and BLUE colors.
Mine is a "B" and Charlies "J"........if I remember correct. Mine is a rev. 1.02 too....
yeah, you place the solder wick on the solder joint of the res and then touch the soldering iron tip to the top of the solder wick, which is on top of the solder you want to remove, as the braid heats, 1 or 2 seconds, the wick will "turn silver" as it sucks up the solder, then move to next side, wiggle and repeat.
C
Mine are red also. I don't think it makes any difference. What is the s/n of yours?
Is the little resistor trashed after if you wanted to re-attach it, or is it just too tiny to sodder both sides back?Quote:
C
Also, if water cooling, is it worth it for an FX53?
no, i don't think it's necc for WC... 1.8v is quite a bit :D
C
I got it all set up last night but can't get the onboard LAN to work. I have not way of downloading the newest bios, clockgen, new drivers, etc. Has anyone else had a problem with the LAN?
Mmmmmmmmm.... never tried that stuff :shrug:
C
It take it you installed the driver and made sure LAN was enabled in the BIOS. If so, try uninstalling and then reinstalling the driver. I'm using a PCI card now because I did something stupid the other day. I was removing a PCI device and forgot to pull the power cord. Anyway, there was a spark and I think I fried the LAN chip. Had to run to the local Fry's store and buy a Gigabit card for $25.Quote:
GUYS!
I Had NO Locks,OR Disable 2T Command on my new A8V with the 1006 Bios it came with!:(
Fortunately, I downloaded the Bios that bigtoe put up in a previous post, and NOW IT WORKS! :banana: :banana:
http://hallowen.freehosting.net/hq1a8vl.jpg
http://hallowen.freehosting.net/hq7a8vl.jpg
http://www.bleedinedge.com/forum/sho...05&postcount=3
If you Can't get it from there, split posted it:
http://www.svcheats.co.uk/asus/A8V-ASUS-Deluxe-1005.zip
Congrats, hallowen. Make sure you set the Memclock ratio to 2:1 DDR400 if you want to run 1/1. BIOS is a little confusing at first.
sierra_bound,
Yeah, I'm finding out Rapidly..This Ain't the Same as INTEL!:D
Amen!Quote:
Sierra, what cooling are you on for CPU and GPU???:confused:
Do you have any vmods?
