hmmmm....that is something different. In that case: :shrug:
Only thing I can think of is that the intel storage driver somehow switches the controller to raid mode, or it does some form of software raid. In the bios, the drives show up as two separate devices and its certainly set to ahci rather than raid.
Also, my reasoning for installing in ahci mode was due to that I could always install the raid driver in windows, and just enable it in the bios. However, if I do that, it gives the same bsod as it did on my old os install. It works, however, so I'm not too concerned with that.
Does anyone know how many RIVE revisions there are and the differences between them? I have a 1.02.
What is your VCSSA on?
Think my CPU started to degrade:shakes:
try this way with your same setting maybe will be help...
shutdown your PC and remove all electrical cable from PSU and your LCD monitor cable to VGA. leaf for while around 1 minute and after that run with normal with your same setting before maybe will be help..I ever have same problem with you I though my chiphave degreed but I using that method my chip back to normal without any problem until now...for run memory 2400 CPU VTT 1.150 - 1.2 Volt and VCCSA 1.1 - 1.150 Volt but all depend your chip
Sadly it did not work:/
I was running 131.6x39 with 1.54 volts, and 1.450 VCCSA, got told that was fine for bench?
OSB, is NOT 24/7 Settings, is only then I bench!
The CPU work fine, but cant get it stabila t 5.133 anymore., fine std ect, "running 4250Mhz at 1.288 24/7.
--> It all started then I putted a 5870 in my PC!, but it cant well be that? will try with my 580 later today.
Im about to buy this motherboard tomorrow (Rampage Formula IV) with a 3820.
Its still a good choice or im better to go with MSI Big Bang 2 or Gigabyte Assassin 2 ?
Thanks in advance
Trying out a new SS unit. Not a very good chip, but havng fun anyway.
I must be losing my mind. I have RAID set under bios but when I reboot and keep pressing CTR I, nothing happens. Is there certain bios versions or something where raid doesn't work? Also, when you press the bios switch button, what is suppose to happen. When I press the button, nothing happens and bios led 1 stays lit, bios 2 led unlit.
With 0013 it won't even post the Intel RAID Bios even when raid is set in the UEFI. I switched the BIOS over to the original shipped BIOS and Raid BIOS is coming up now. Not sure why it is disabled in 0013.
What exactly is the difference between the four number bios's that Asus puts out and 00xx versions of the BIOS's?
Raid works fine with bios 1005, but I had to load the raid driver off of the disk.
http://hwbot.org/submission/2236316_...60x_7868_marks
RAID SUCCESS!
I could kiss these guys. Post #2 worked. I am going to hold onto that file for dear life. It is the only thing that worked.
http://hardforum.com/showthread.php?...ight=raid+asus
Disregard
