That NB clock is pathetic! Having a high NB is just as important as the CPU clock itself!
This is with ambient temp around 27-28c :mad:
CPU Model: AMD Phenom II X6 1090T BE
CPU Stepping: -----------
CPU Frequency: 4014 MHz
CPU vCore: 100% load 1.43V
CPU Multiplier: 20x
CPU Turbo: Disabled
CPU NB Speed: 2600 MHz
HT Ref Speed: 200 MHz
RAM Speed: DDR3-1333
RAM Timings: 7-7-7-20-1T
RAM Configuration: 8 GB (2 x 4 GB)
RAM vDIMM: 1.5V
Motherboard: ASUS CHIV formula
Chipset/Socket: AM3, 890FX + SB850
Cooling: Thermaltake Frio
Temps: 35C Idle / 54C Load
Operating System: Windows 7
32/64-Bit: 64
Stable/Suicide/Untested: Stable " Prime95 "
http://img189.imageshack.us/img189/7098/22900813.jpg
http://valid.canardpc.com/cache/banner/1890213.png
Much better :up: You are getting the hang of this rather quickly.
Thanks :) I'm working on less V stable 4GHz. I'm also getting some new rams Musking Redline @2133Mhz very soon. that should give me more things to play with!
I got better V now 1.376V Idle & 1.402@ 100% load
Tested for 10+ hours and not a single error.
http://valid.canardpc.com/cache/banner/1890991.png
http://img3.imageshack.us/img3/3668/lessv.jpg
Try to run 1000% memtest w/98%mem usage to see if nb is stable,I know you only have 2 sticks but 1.4 sounds low even w/ high nb volts you need decent cpu volts.
Whenever my NB was unstable my systme would freeze and there's no BSOD or nothing at all. and that only happens when i try Prime95 for less than an hour.
I would not sale/use a overclocked system unless every thing has been tested for 24/7 stability.Some software could stress it and bam reset or freeze.Why because nothing is guaranteed.
So, a full week of testing for stability?
that's both true and false at the same time. depends greatly on the motherboard, LLC makes stability testing a nightmare as I've find myself having to overshooting where I need be at by around 5-10% just to keep idle LLC above the stability line.
you can pass prime95 blend for hours, days, even WEEKS but the minute you stop testing and LLC goes from load to idle, a bsod or freeze can occur :rolleyes: to make matters worst there aren't many tools around to testing the idle state of LLC
So why overclock at all then?
You're talking about testing an overclock for 24Hrs with EVERY available bit of stress testing software there is, Which would take WEEKS!
And how would you know if you've failed because of voltage or heat?
I personally run an hour of P95 with custom settings then 50 runs of Intel Burn Test and if it passes then it's stable.
Some people need to stop with all this 24Hr stress testing bulls**t and actually learn to enjoy using there machine what it was built for and not wait around for days testing it for instability issues that they'll other wise never see using it normally.
Most use their systems for 2-3 yrs so a week of testing is moot.
A crash is not tolerable gaming or working.
Ever heard of quality,well it don't come from nowhere.
Someone it testing to make sure it works @ advertised spec.:yepp:
Is there a way to download the stable chart in a spreadsheet or at least CSV or something that is more readable? That PNG is very hard to read.
Can you guarantee that your clients will never reach 100% load.;)
Can you guarantee that your Electronic equipment will work as they are meant to? :welcome:
