Had my HT up in "sync" with my NB for a while (around 2400-2450 MHz) with no problem other than heat. Lowered down to 2000 to shave off a couple of degrees, while keeping NB at 2400+. It should work! (I imagine(?) that 2400/2400 "felt" :rolleyes: smoother than 2000/2400, but I am probably wrong...)
What bios do you use? Did you load default setting after flashing (if you have flashed)? Do you overclock in bios or via AOD?
