OK, I've got a problem measuring, probably cos of my incompetence, but wanted to recheck with you guys.
I did use the above URL, and
picture that is shown there. But I couldn't get any numbers from my multimeter, though it could be that I've missed the point somehow, even though I've tried 5-6x..
So let's take it step by step, as I don't use MM usually, and I've borrowed this one just for the occasion ;)
1) I take multimeter and turn it on
2) I have a switch and a dial to set up the desired range
a) little switch that selects amps/ohms/and two types of voltages. One is V
http://i259.photobucket.com/albums/h...xZg/V-isto.jpg (that's DC right? or not?) and the other is V~
http://i259.photobucket.com/albums/h...xZg/V-izmj.jpg (AC?). I'm not certain which of the two is right (that's why I've included pictures, I hope they are shown right in post), as I'm not sure if GPU voltage is AC or DC.. Though I was just struck with the VD
DC markings, but it could mean anything as I still don't know what MVDDQ means either except that it's some memory voltage :D So I guess it's DC, but tell me anyway, is it this one
http://i259.photobucket.com/albums/h...xZg/V-isto.jpg or this one
http://i259.photobucket.com/albums/h...xZg/V-izmj.jpg ?
b) next I have a dial that's similar to this one
http://i259.photobucket.com/albums/h.../th_V-dial.jpg; it lets me select 2/20/200 for whatever I've selected on the switch (ohms, amps, volts). Should it be better to select 2V or 20V, since VGPU is <2V actually, I guess 2V is better and more precise, right?
3) I take those black and red umm "cables", and I put one on the VDDC measurement point on the VGA card, and other one where? As much as I know, it's just important that circle is closed, so I've just put the other side on the PC case.. It worked fine when I've tried to measure current on peripheral/molex plugs, showed 5V and 12V no problem.. But if VGPU is DC than what? And I guess than there is difference between using red or black one.. So a bit more info in here as well..
There are few things I could have missed, I'm no longer sure, but maybe I've switched to wrong voltage type (step 2-a). Also, maybe my PC case is not good for closing the circle when measuring VDDC on GPU (step 3), or i've just placed wrong red/black cable on the measurment point. Also, I could have missed the measurment point completely, so I didn't have good enough contact. Anyway, please, step-by-step instructions would be real nice, so I can do some measurments today or tomorrow when I should also have IR thermometer and power consumption meter, so I can check what are the effects of voltage/clock changes in BIOS, and how will it all affect stock cooler vs aftermarket cooler..
Thanks in advance :D
