i am waiting for xfx p04. if anyone has it pls share it.
Is the 0601 for S2E still have the overvolting problems
There's a Striker II Extreme dedicated thread for these stuff.
However... I don't expect Asus to adjust ( rename to be precise ) their BIOS values to match the real ones.
Plus that there's a variance between different boards.
Are you basing your overvolting "problems" on DMM measurements or with software measurements ?
OK, so anyone else getting randon pausing in games??? if i press the window key goes back to desktop then i can switch back to the game, wierd, anyone else???
Yeah actually, I've been getting some weird video hiccups. I'm not overclocked currenty- Waiting for water cooling, and I'm using the P03 bios . Hope that helps.
Is there any tool for 790i to up the FSB in windows? Can't find anything.. :confused:
I've just had to install this version 6.10 esa to get it workingQuote:
http://downloads.guru3d.com/nForce-n...load-1869.html
RLM
Looks pretty good, as far as tweaking.
http://img242.imageshack.us/img242/4...e610esatg0.jpg
RLM
Thanks, but i do not like any drivers on my SuperPi-OS.
But no need for it anyway. Can boot with 562MHz, but SPi fails. With intel most time you can get some more stable MHz with windows-tools.
The green spots ( could be the blue ones, I don't remember for sure, I will set up the board later and check back )
http://i30.tinypic.com/1t0x9k.jpg
many thanks :D
i don´t trust Everest and Bios ;)
Cas7 still has a bug while gaming, i turned it up to cas 8 and seemed to fix the stuttering freezing issue.
Striker II Extreme feels way better with 0601 ( still on initial testing though ).
CAS Latency 5 bug is fixed now.
For a starter a low Everest:
http://i31.tinypic.com/29e214w.png
My new 24/7-settings:
http://www.abload.de/img/4gb_dual32m_800mhz_7c9t.jpg
http://www.abload.de/img/4gb_dual32m_800mhz_701n.jpg
Can't remember when i had so much fun with a system last time. This board really rocks here! Don't know why there are so much problems. Maybe i just have a lucky board. :)
Will test 900MHz 7-6-5-20 1T 1,94V later. Both kits can do it alone, but don't think in this combination. ;)
Aight so P1+P2 enabled works with 4 sticks and even with 1T... nice. Thx for the pic flix
