Yes it is with dry iceQuote:
Originally posted by cold_ice
Is this 2.8 533FSB OC with dry ice too?
Thanks :DQuote:
Originally posted by macci
Try setting boot up FSB below 200MHz ?
Like 199 and then up it from Windows w/ Setfsb. Should give you the ram divider you want :)
I must have been inhaling too much ethanol+CO2-fumes yesterday because I didn't figure that out...
I did some more test on the dryice-leftovers today, and achieved this with the 4:5 divider:
http://www.silentworks.net/sekalaise..._333div_1m.jpg
Too bad my BH-5's didn't go any faster, I gave them 3.6 volts.
And here is the newest record on my 2.8A chip:
http://www.silentworks.net/sekalaise...4700mhz_1m.jpg
:toast:
Just wondering would it pay off to put some LN2 in the tube? Would 5GHz be reachable on this chip?
I got one...:D
http://www.e04hardware.com/record.jpg
Where can I find the Japanese version op superpi ?
http://membres.lycos.fr/boblemagnifi...superpi36s.png
2500M AQYHA 0410 TPMW
DFI Ultra Infinity
2*256 BH5 2/2/2/11 Synchro
Full Air :)
Damn...everything is right..CPU mobo etc, couldnt get the LN2 working, i give it a try end of this month:)
r404(not 100% tuned)
http://www.gabbax-projects.com/8m%20copy.jpg
EDIT "Hilppa" Yes i do think u can easly reach 5ghz with LN2.
Not a fast time except that it's 80 F and I'm cooling with a 92 mm tornado and a Thermalright 900A... :D
http://img.photobucket.com/albums/v3...s/MaxedAir.jpg
I really think there is something wrong with your system, since here is what I came up with 2.8C at the same clockspeed and some -10 Celcius degree water:Quote:
Originally posted by gabbax
[B]Damn...everything is right..CPU mobo etc, couldnt get the LN2 working, i give it a try end of this month:)
http://www.silentworks.net/sekalaiset/Snap2.jpg
EDIT: My mistake at this time of the night, didn't notice you had the 2.8A... would you mind telling te FPO/BATCH number of that processor?
Yepp ofcourse "L408B106"
Yess its easy to do a mistake;)..But its seems that ive fixed it with "tonys aka BigToes" unleashing DDR533" BIOS, i can crank up the Mem sped now, at 171FSB(AIR) mem doing 226...but it seems this BIOS have a coldboot issiue? wont let me start....with r404...
For what mobo is that bios for? P4C800**? If you could throw me link to those files I would appreciate it..
Propably no point in asking, but have you set the cpu temp from hardwaremonitor to "DISABLED"?Quote:
Yepp for the P4C800-E del
Yes its all deiss...damn, id luv to hear what BigToe have to say about this:)
heres the Link
Unleashing DDR533 on P4C
Thought I may as well reply here for my first post.
here's my Super PI bench.
http://img.photobucket.com/albums/v1...k/super_PI.jpg
nothing but my video card overclocked.
ram set by SPD.
i think asus probe is accurate as far as the volts go...and thats an idle temp. This is my current top end for stability, but I'm swapping memory tomorow thats rated for 216mhz 2-3-2-6, so this might get better.
http://img44.exs.cx/img44/5384/32secondsScreensmall.jpg
2 awesome scores with DDR2 :slobber:
CPU : Pentium4 560 ES , V Core1.6175V
Cooling : Retail Sink+SANYO92mm*2+Aguri stops simply!
M/B : ABIT AA8-3rd Eye (i925X)
Memory : SAMSUNG K4T56083QF-GCD5 422 PC2-4200 256MB (Dual)
OS : Win Net-Server 2003 iAg‰ü with Team AB-Boy+SP+TDj
Room temperature : 15Ž
http://members.jcom.home.ne.jp/aguri...16-pi1M27s.png
CPU : Pentium4 560 ES , V Core1.5875V
Cooling : Retail Sink+SANYO92mm*2+Aguri‚ª:banana:ȈՂɗ¯‚߂܂·I
OS : Win Net-Server 2003 iAg‰ü with Team AB-Boy SPj
Room temperature : 20Ž
http://members.jcom.home.ne.jp/aguri...0x16-1M28s.png
mon dieu!
doh
Holy crap. That's about 3 seconds faster than with 2-2-2-5 DDR1 memories running the same speed. Anyone want to buy 2-2-2-5 260Mhz @3.5V BH-5's? :p:
I guess the board (chipset) helps alot too... could someone post some results on 915 chipset and DDR1 memories?
Thats not even DDR2-533, I'm sure its running higher than that, the memory is just running faster than the bus.
I don't get it!!!.......I sure don't like something here.... :rolleyes:
hmm ddrII ey...these must be running an astonishing speed to get that result.. seems fishy..
Not bad, mate :thumbsup:Quote:
http://www.home.no/f-14jmr/BIT%20TEC...s%20hahaha.PNG
Vapochill PE
A64 3200+ clawhammer @ 2650mhz
Gigabyte k8nsnxp (waiting for the DFI so I hopefully can push my cpu further)
1X1gb OCZ EB platinum
