Shots aren't that bad, but your rig could do with some serious cable management and a stronger pump. CPU, NB, SB, 2*MOSFET and VGA all in the one loop is a hell of a lot for what I'm guessing is a topped DDC :shocked:
you are both right ;)
i really have to think about my calbes... but it's :banana::banana::banana::banana:ing narrow in there...
and yes, the pump really is on a limit. i bought the pump, cpu-cooler and radiator from a friend, so i was thinking about adding a second laing ddc (maybe the ultra version) after the nb. i was just wondering, if this really helps my temps (53° at full load; Q6600 b3-stepping @3,2ghz 1,36V).
but i guess it's of-topic in this thread, isn't it?
german style :D
I think it's not to bad. The Laing should be enough for that setup. I'm running with an Eheim 1048 with CPU/GPU/NB/SB/Mosfets and a 3x120mm rad. I know i could use a better pump but my setup is working fine with good temps. His Laing is alot stronger than my pump.
Here's a pic of my setup.
PilatuS, nice rig. Wish I was in The Netherlands right now! At least, I live in New Amsterdam, but the time is nearing for my 3rd visit to Holland.
still a work in project... gotta tidy up some cables, re-work how my pump is going to fit, and some paint, dent removal, and to make a bezel for the fans on top and straighten them out as well :hammer:
http://i48.photobucket.com/albums/f2...Picture023.jpg
http://i48.photobucket.com/albums/f2...cture018-2.jpg
http://i48.photobucket.com/albums/f2...cture016-1.jpg
http://i48.photobucket.com/albums/f2...Picture020.jpg
fan controller makes this machine nearly silent. :up:
of course i have to turn them up when gaming but whatever, i use headphones.
3 rads in that space... looking for room for a few more :p:
Nice setup :D
The rug is awesome!
@knet
Doesn't the Dye cause stains?
@fireice2
it stains so bad, the tubes turns uv reactive when you put just clear distilled after draining the coolant. ;-) well im just looking for a reason to change tubes anyway. hihi..
hahaha. Awesome rigs people :up: to joo!
i enjoy looking at build pics so i figured i would post a few.. I didnt clean up the wiring because within the next few weeks i may be changing to a maximus/rampage formula and a 9800gx2.. also im going to rebuild it once i find an acrylic top for my EK supreme..
Anyone know where i can find an acrylic top for my EK supreme in the US???? petras has been out of them , they said atleast a month before he can get anymore
specs are in sig
http://home.comcast.net/~ubc_ccc/evga780i/evga1.jpg
http://home.comcast.net/~ubc_ccc/evga780i/evga2.jpg
http://home.comcast.net/~ubc_ccc/evga780i/evga3.jpg
http://home.comcast.net/~ubc_ccc/evga780i/evga4.jpg
http://home.comcast.net/~ubc_ccc/evga780i/evga5.jpg
http://home.comcast.net/~ubc_ccc/evga780i/evga6.jpg
http://home.comcast.net/~ubc_ccc/evga780i/evga7.jpg
http://home.comcast.net/~ubc_ccc/evga780i/evga8.jpg
nice setup
Well, at least you didn't order a GTS, then I'd have had to rail you for that too. :ROTF: I'd rather have seen a MCR in there though.
As for everyone hating Tt, yeah kinda. When they decide to leave the Alum for their cases only and make quality WCing products that work well, attitudes around here may change. I mean, ppl can only put up with pumps quitting, res's cracking, weak flow, poorly designed or alum rads, and cpu blocks cracking for so long before they rise up and beat the snot out of someone. ;)
Hey there. Im new to the forums..posting wise (ive just been looking around)
so ill just post my stuff. i know i need to fix the wires but this is what i have.
i have a 3dmark06 of 15500..is that good for my specs?
thanks!
http://i210.photobucket.com/albums/b...rrapppp003.jpg
http://i210.photobucket.com/albums/b...rrapppp002.jpg
http://i210.photobucket.com/albums/b...omputer002.jpg
lol, no grill on that delta fan (granted its tbe back), still cats tail gets a little to close...
"Thermaltake Executive beatin to death. Killer leaves his signature piece of copper waterlogged in a shot glass behind" --thePhonyPaper, April 26, 2008Quote:
Originally Posted by waterlogged
:shocked:
:clap:
Yeah careful with that uncovered delta.
it'll cut your finger off...
Well maybe not completely, but it'll probably require stitches...
well yeah i put a grill on the back so no cables got sucked in..god forbid. there is some what of a grill on the front. but yeah i gotta watch out :)
nice
