Don't remove EZ_RAID jumpers!
Sorry to resurrect an old debate but I wanted to share some information with long-time users of the P5W DH, in this thread I've taken real good advices and info... :)
Last post about this is dated 2008, but this is still giving me headaches!
I've experimented using EZ_RAID1 port with RAID_SET jumpers taken apart (and EZ-Backup mode change enabled on next reboot). ICH7R is set to [Raid].
While the EZ_RAID1 port might be recognized as the missing ICH7R port, and the connected hard drive correctly identified and working, I came across an issue: reading and writing may take ages, as if the drive was not responding. A simple 10MB file copy may even take 5 minutes! :confused: Even Windows won't shut down.
I've used this "no jumper" setup before to temporarily attach a drive before and did not noticed the problem. I was running XPand maybe no RAID, can't remember.
Today, I'm running Windows 7 with latest Intel drivers, with a RAID1 on ICH7R SATA3 and SATA4 ports, a system drive on SATA1.
Edit: The culprit is JMicron driver! Thanks G40RoCkEt :clap: for having pointed this, I would not have even been thinking that the driver of a separate controller could cause problems with a specific port on another one! :down:
Removing the RAID_SET jumpers is a clear mistake, as the Sil4723 chip seems to keep interacting in a bad way on the connection, at least when ICH7R is configured as Raid.
Edit: Actually, this can be still true, but JMicron driver once uninstalled and back to Microsoft generic AHCI driver, the problem seems gone for good.
I've also taken a look at the manual: it says that you must put the jumpers in RAID1 configuration, plug the drive on EZ_RAID1 and leave the EZ_RAID2 free, in order to setup a RAID10 with 4 drives using ICH7R...
So this might not be an issue in others modes than [Raid].
Now that I have putted the jumpers back to RAID1 mode, the problem is gone. The drive attached alone to the EZ_RAID1 port is performing as expected, not as it would on a regular ICH7R port, but without issues. :shrug:
Edit: I've experienced some random freezes since with iaStor problems showing up in event manager. Reverted back to Matrix Storage driver 8.8.1009 as advised by Intel communities forums -> Problem still here (note better general responsiveness!). JMicron driver uninstalled, problems gone!
Voila, that's all for my report.
Edit, I'm investigating whereas it's a problem with the driver or a version of the driver or even a problem under Windows 7 with the driver. I'll post my results here :)
Hope this can still help, even it's a bit late!
Cheers!
Alex.
