Originally Posted by
pc1x1
Anyhow I got everything installed:
Asus P5WDH Deluxe
Quad 2 Core 9550
4 Gigs of Corsair XMS2 Ram
Radeon 3870x2
PC Power & Cooling CrossfireX 750W
Bios is 2901.
Here are the problems and my solutions:
Problem:
Computer automatically restarts when shut down.
Solution:
Found to be a USB port issue having to do with Suspend, Ports 3 and 4 are unusable in the motherboard.
Problem:
USB Ports always Powered, does not shut off hubs or external hardrives.
Solution: None, except shut off the power manually from power supply, (switch off)
Problem:
External Hardrives take a little while to be recognized in Windows, seems to be USB issue again?
Solution: None, just wait, afterwards works fine.
Problem:
Catalyst Control Center is Buggy, 9.9 design is horrible, 9.8 they were in the right direction, now its back to being buggy.
Solution: None, use UltraMon for multi monitor support, only use CCC to activate CrossfireX
Problem:
Fails Boot, even not overclocked this motherboard exhibits the same problems as my P5WD2-E, sometimes on restarts it freezes on Boot up, before windows.
Solution: None, hard restart
Anyhow guys, those are my problems, feel free to chime in, I really wish theres was something that could be done to those USB ports, uber annoyance.
Thanks!
