Looks like a MIPS block. http://www.mips-computer.de/
Looks great, funkflix :up:
Found it, but
Preis: 89,90 EUR
New case.
Gee thanks. It was a fricken snapshot, dude and it needed to be brightened up. When I get the mod done, I'll take better pictures and you will be welcome to critique them. Better yet, travel to Denver in July and you can see my exhibit I'm putting up in a local gallery. I'm sure they suck too.
Thermochill PA 120.3 is no longer in the list of FrozenCPU, WHY???
and found this Feser X-Changer, with tag line "Thermochill Killers"
Any Comment on both X-Changer and 120.3?
i wouldn't comment on thermochill killers until i see perf results sounds like alot of hype tbh
I am looking forward for a review comparing thermochills vs. the x-changer...
if you find any, kindly share it here... Thanks!
@Schlingel - nice pics!
Ybris A.C.S. BLACK PEARL Gold
http://www.pctunerup.com/up/results/...2_DSCN1386.jpghttp://www.pctunerup.com/up/results/...4_DSCN1392.jpg
http://www.pctunerup.com/up/results/...1_DSCN1384.jpghttp://www.pctunerup.com/up/results/...6_DSCN1401.jpg
http://photodorp.com/images.php/i38_DSCN1307.JPG
http://photodorp.com/images.php/i35_DSCN1303.jpg
http://photodorp.com/images.php/i37_DSCN1305.jpg
http://photodorp.com/images.php/i36_DSCN1304.JPG
http://photodorp.com/images.php/i40_DSCN1314.JPG
http://photodorp.com/images.php/i39_DSCN1310.JPG
http://photodorp.com/images.php/i47_DSCN1340.JPG
http://photodorp.com/images.php/i44_DSCN1324.JPG
http://photodorp.com/images.php/i43_DSCN1318.jpg
http://photodorp.com/images.php/i42_DSCN1317.JPG
http://photodorp.com/images.php/i41_DSCN1316.JPG
http://photodorp.com/images.php/i45_DSCN1332.JPG
http://photodorp.com/images.php/i46_DSCN1336.JPG
Just finished modding a Stacker 830 SE, was kindda hard as the emplacement for the rad couldn't be used due to the PWM heatsinks on the mobo... So I had to move everything as far as possible to the left side... bundled with the too many connectors on the PC Power Cooling PSU which are impossible to hide lol... this was a pain in the butt to accomplish... really thought these cases were bigger...
http://users.pandora.be/OAP/Nils%20003.jpg
http://users.pandora.be/OAP/Nils%20004.jpg
Nilos Specs are
Gigabyte P35DS4
Intel Qx9650@4ghz 1.32Volts
2Gb Team Extreem PC6400@1000mhz ram
Palit 9800X2 Vidcard
2 x 150Gb Raptors in Raid
2 x 500Gb Samsung drives
Swiftech MRC220 - Laing DC1 - Ek Supreme CPU block - EK 150 reservoir
Lee what size tubing are you currently using?
3/8 it was, my friend thought it was 8/10mm so I bought some new tubing, though when I tried to fit them it was a no go and had to reuse the old ones... pretty cool temp on the Qx at 4ghz around 35°C idle and topping at 57°C under small FFT's ( all coretemps due to Vista )... gonna clean my Thermochill triple rad and use these 3/8's too instead of my thinner tubing...
Couldn't you mount the rad on the underside of the case so that just the fans are on the inside? This is what I'm looking to do with mine (will need the wheels fitted though)
It's still running hard man! I never had a comp running so well for so long :rofl:
I haven't changed a thing on it and i won't for a while. Alltho I'd like to upgrade for a 45nm CPU, a 790I SLI mobo, some DDR3 and some 9800GX2, i can't ATM and probably won't be able to any time soon.
The material life is taking over with the girlfriend :yepp:
a (so i hope) better pic :)
http://www.abload.de/img/gesamts4r.jpg
That's an option Nf, but the Swiftech rad is already pretty thick, if you have a thermochill that's even thicker. Me and Nilos transport their pc's regularly to LAN's so a rad on the bottom could be easily damaged... I prefer it to have on the inside as the tubing is also easier to do...
If you look closely the rad is only mounted via 2 screws on Acryl plates...pump also rests on a foam (for vibrations) so the complete setup is pretty easily removable... but a rad on the outside would have made the installation way easier....
I'm looking for a Cosmos S modded case, as I think I can put my Thermochill triple rad on the top of the case... but haven't seem many mods on that case ( yet )
Like I said before the Stacker is huge though once you put in 4 Hd's and 2 optical drives things can get stuffed, and without a modular PSU things get pretty messy on top...
http://keep4u.ru/imgs/s/080128/b1/b1...b08b3b8659.jpg | http://keep4u.ru/imgs/s/080128/8e/8e...a86781d9fe.jpg | http://keep4u.ru/imgs/s/080128/80/80...a7e1f0f090.jpg
http://keep4u.ru/imgs/s/080216/6b/6b...882555aa01.jpg | http://keep4u.ru/imgs/s/080216/88/88...25b8608013.jpg | http://keep4u.ru/imgs/s/080216/17/17...b1524a19a9.jpg :welcome:
