no have not had the chance too, sadly I'm waiting on the mosfet blocks still, XS member mailed them April 13th and there still not here, going to wait the rest of the week b4 I start to investigate.
hey guys, i have this board (maximus forumla)for a year now, and have 2x1gb corsair xms dominator's (ddr2 800) but i wanna get 2x2gb and im not sure what you guys recommend and if i should get 800, 1000, or 1066, etc. What do you guys recommend, i have a mild overclock of 9x400, keeping my memory 1:1 so just cpu is OC'd 600mhz.
Im thinking either muskin mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model 996599 - Retail
or mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory Model 996593 - Retail
or CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X4096-8500C5D - Retail
should i stick with w/ 800 or go higher? i wouldnt mind running my fsb higher and getting my cpu @ 4gh or 3.8
G.SKILL - F2-8500CL5D-4GBPK
http://www.newegg.com/Product/Produc...82E16820231166
Shawn,
Thanks for the quick reply, this may sound stupid but, I have a black & red theme going on with my WC system. Do they make that in a different color or any other ram that is black or red that you could also recommend? :cool:
edit:
found the F2-8500CL6D (there red) but timing is 6-6-6-18 :(
I believe these are the same, just a different heat sink.
http://www.newegg.com/Product/Produc...82E16820231246
Might be selling my board and chip soon guys. Just a heads up...
Speaking of memory. Shouldn't I have better speeds then this?
http://i223.photobucket.com/albums/d.../OCing/mem.jpg
Finally got my beast of a chip at 3.6 prime stable.
It was NB temp causing my issues before. Going with the slower Kingston RAM instead of the Ballistix seems to have kept the NB temp under control.
seem slightly off... heres mine
http://img2.pict.com/be/59/94/7c79ad...MfMh/mymem.jpg
Hi Guys,
Just noticed the Rampage Formula got new bios on Asus site.
Version 0902
Description Rampage Formula 0902 BIOS
Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/c...Language=en-us
File Size 1002.14 (KBytes) 2009/05/04 update
Download from Global China P2P
Version 0803
Description Rampage Formula 0803 Bios
Improve compatibility with some Raid card
File Size 1002.84 (KBytes) 2009/02/25 update
Version 0701
Description Rampage Formula 0701 Bios
Fixed use 2 pieces of ATI4870X2 VGA Card can't display from Primary slot display monitor
File Size 1000 (KBytes) 2008/12/10 update
The last one from 04/May/2009 - WoW
And, any advice to convert ( i mean ) flash maximus formula to Rampage formula using afudos and one of those bios. The last link posted on first page was to a beta bios 0403 - that's pretty old. Any performance test with those bios ...
It's just download and flash it, or it need to be modded first, or any other thing.
Thanks a lot for your Help
ASUS Rampage Formula BIOS 0902 Official
is giving people lots of problems , my self included.
So be aware
[QUOTE=A-Grey;3772724]Visit the ASUS rampage Formula forum and add your thoughts to the ASUS Rampage Formula BIOS 0902 thread.
[QUOTE]
Hey for stable my overclock whit 4X1Gb @1000Mhz i need 1.55v VNB!
I think high this voltage :S
With two modules 2X2Gb necessary lower VNB or same for 4X1Gb ???
i ran my 2x2 @ 1.47.. a little lower then my 4x1 @ 1.51 set in bios which is about 1.55/56 real..
dang i got over night past prime blend at 4.5 with my settings. i fail occt about 1/2 hour in.. i upped the volts a little more to see if i could get occt but temps got to 77 eeeeks, turned it off.. occt is a animal, load temps 10-15 degrees higher then prime blend.. i have played games on the settings @ 4.5 all day long for days with out any crashes or noticeable problems and never see my temps get above 55 on a hot day.. i just went through 10 passes of intel burn test at the 4.38 settings 63/64 degrees no problems but at 4.5 the temps got up to 77 so i shut it off..
Yo guys,
I had some problems with my adi sounddriver soundMAX so deinstalled it.
Does anybody have a good one for my converted Rampage Formula?
Can I use the V610X6480_zip diver?:shrug:
[QUOTE=neo_rtr;3777230]ASUS Rampage Formula BIOS 0902 Official
So be aware
Thanks for info.
Btw, i've noticed your are using 0803 as described on your sig, how is it doing ? I'm still on very old beta bios. Can i update it ?!
i have hit a wall with my e6600 at 3.4ghz
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8
FSB Frequency : 425
FSB Strap to North Bridge : 400
PCI-E Frequency: 110
DRAM Frequency: DDR2-850
DRAM Command Rate : 2t
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
DRAM Static Read Control: disabled
Ai Clock Twister : stronger
Transaction Booster : 7
CPU Voltage : 1.41
CPU PLL Voltage : 1.5
North Bridge Voltage : 1.4 for 1.44 real
DRAM Voltage : 2.06 for 2.10 real
FSB Termination Voltage : 1.25
South Bridge Voltage : 1.07
Loadline Calibration : enabled
CPU GTL Reference : x63
North Bridge GTL Reference : x67
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : AUTO
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
any help to get past this would be appreciated
cpu vid is 1.35 :(
cpu is cooled by a true and stays under 56*C under load trying not to go over the recommended 1.5v vcore
http://www.xtremesystems.org/forums/...d.php?t=181921
Updated Soundmax drivers v6.10.2.6520 dated 10/07/2008
Thanks for info.
Btw, i've noticed your are using 0803 as described on your sig, how is it doing ? I'm still on very old beta bios. Can i update it ?![/QUOTE]
Yes for my self did some magic back then and i was able to OC with lower Volts.
After the 0902 trip i got issues back in 0803 but with higher volts.
go with the 0803 and i think you will be just fine
This is mine
http://img87.imageshack.us/img87/962...bsrrt45xg7.png
By neo_rtr at 2008-08-14
there is a difference.. hmm..
