nice res, the blue water one, which type is it?
there are plenty of "blue water" pictures in this thread lol :)
@adidassler
nice, looks great.
@B@bel
looks nice and clean, good job :yepp:
I'd suggest you replace those S12s. While they're great fans, they're not designed to work in high-impedance situations as they have a low static pressure. By comparison, Noctua's P12 fans have a much higher static pressure and will give you better temps for about the same noise level.
Re build from old case.
Case: Lian LI v1200 Plus II
Rad: Black Ice GTX 480
Block: Thermalright
VGA Block: Zalman GTX/Ultra
Tube: UV 12mm.
Tank: Mica made by nhenhopach.
Pump: Swiftech MCP6555.
Fans: Zalman
UV Tube
http://i184.photobucket.com/albums/x...h/DSC00378.jpg
Rad 480GTX
http://i184.photobucket.com/albums/x...n/IMG_0758.jpg
http://i184.photobucket.com/albums/x...n/IMG_0760.jpg
Tank
http://i184.photobucket.com/albums/x...n/IMG_0767.jpghttp://i184.photobucket.com/albums/x...n/IMG_0770.jpg
Finished
http://i184.photobucket.com/albums/x...n/IMG_1005.jpg
http://i184.photobucket.com/albums/x...n/IMG_1006.jpg
http://i184.photobucket.com/albums/x...n/IMG_0982.jpg
http://i184.photobucket.com/albums/x...n/IMG_0986.jpg
http://i184.photobucket.com/albums/x...n/IMG_0988.jpg
CPU--->VGA---->Chipset--->Rad--->Tank---->pump---->CPU
http://i184.photobucket.com/albums/x...n/IMG_0989.jpg
http://i184.photobucket.com/albums/x...n/IMG_0991.jpg
http://i184.photobucket.com/albums/x...n/IMG_0993.jpg
http://i184.photobucket.com/albums/x...n/IMG_0996.jpg
http://i184.photobucket.com/albums/x...n/IMG_0997.jpg
http://i184.photobucket.com/albums/x...n/IMG_1000.jpg
http://i184.photobucket.com/albums/x...n/IMG_1002.jpg
http://i184.photobucket.com/albums/x...n/IMG_1014.jpg
http://i184.photobucket.com/albums/x...n/IMG_1027.jpg
http://i184.photobucket.com/albums/x...n/IMG_1033.jpg.
WOW Nice V1200. I LOVE that case.
Nice job nhenhophach. What type of chipset wb are you using?
http://www.pctunerup.com/up/results/...d_SNC10021.jpg http://www.pctunerup.com/up/results/...d_SNC10031.jpg
http://www.pctunerup.com/up/results/...rafie-0088.jpg http://www.pctunerup.com/up/results/...7012805_12.jpg http://www.pctunerup.com/up/results/...7012909_14.jpg http://www.pctunerup.com/up/results/...7012932_15.jpg http://www.pctunerup.com/up/results/...7012945_17.jpg http://www.pctunerup.com/up/results/..._resized_4.jpg http://www.pctunerup.com/up/results/..._verticale.jpg http://www.pctunerup.com/up/results/...ArmorMod70.jpg http://www.pctunerup.com/up/results/...ArmorMod73.jpg http://www.pctunerup.com/up/results/...rafie-0096.jpg
Link to thread:
http://www.pctunerup.com/up/results/...094211_web.jpg
@TROJ@N: interesting you didn't get the DFI LanParty UT/LT version, at least it would go along with your green & black theme :D & how'd you get to get that fan on top of the vidcard to stay?
@fireice2
Thanks a lot Mate...
@canadmos
haha, iphone, nah, its just fine...
not able to read the text? hmmm.... i have no bigger image than this.
i limited the size into 600x450, it is a ritual in our own thread in the philippines. haha
@gen
Thanks man. =)
@pattherat111
Lols...
it's a nanoxia
yes...nanoxia fx2000
Agree with soul...
I have the NH-P12 and dropped 3C on LOAD and 2C on IDLE, before that i have the sytche slip streamed
http://s1.subirimagenes.com/otros/pr...25p1000575.jpg
super clean trojan
Disruptfam, How well do those compression fittings work? reliable?
