Originally Posted by
loften
yeah that is pretty neat.. the cooliest thing i have seen all day.. did you feel it when it took off? as for the se.. i am having a little harder time getting 4.5.. i tried going up a little on pll, cpu and fsbt from where they are at the 4.38 setting in the above post.. i tried this,, cpu 1.39 and 1.40 real, fsbt 1.32 real, pll 1.64 real. just a bump or two more then before in bios.. i am wondering how much volts/heat the cpu can take.. at those settings the temps were 59-60.. still a little lower then it was on air but core #1 failed prime blend, test 2 on the second pass a couple times.. before i got the right combo for 4.3 core #0 was failing the same way... kind of wondering if i should push a little more volts or be happy with what i got.. vid on cpu is 1.25 so i think it may not be a very good clocker for volts.. at 4.3 we have been playing games since my last post pretty much non stop and it screams.. my 12 year old son says it is so smooth.. he's pro at ut2k4, been playing it since he was about 7.. pwn's me.. i have to turn off crossfire in that game and just run one hd4870 because the screen is all tore up when running both.. i am pretty happy with 4.3 but still wondering a little because i have never even been here before and stable..
