Yes i know it now. Got M380 for 35 Eu :)
Oc is a little better than mine M370. Without mod running Prime stable 1.6@2.64 @1.55v
Great power for this money. :D
So you can assure me upping the Vcore in the BIOS is possible with a CT479?Quote:
Originally Posted by krick
I thought somewhere on the box or in the manual it said you shouldnt do that? :confused:
BIOS vcore options work perfectly, just like they do with P4s.
I have a problem where high vcore limits my FSB overclock. 1.425v vcore lets me memtest stable at 260MHz, but 1.55v vcore gives me only 240MHz, and 1.6v gives me 235MHz. Anyone else get this? The errors show up in memtest86+ test #7, by the way...
OMG and here i was considering voltmods, because i read somewhere that vCore + Asus CT479 wouldnt work. :X
I did a little more playing around with my P4P800-VM system last night and I discovered something really strange.
The way the system was set up, I had 2GB of memory. Four 512MB sticks, all generic cheapo memory. I set the memory settings to auto by SPD in the BIOS and set the memory speed to 266. Then in windows, I was able to crank the CPU front side bus up to 2.2GHz. I could go as high as 2.4GHz but it would randomly lock up after a while, but 2.2GHz was rock stable.
Last night, I swapped out the memory and replaced it with two Crucial TWINX 1GB sticks. Setting all the BIOS settings exactly the same, I boot into windows and I cannot overclock using clockgen *AT ALL*. Even slightly overclocking results in a hard lock or reboot.
I even tried going into the BIOS and manually setting the latency settings and it makes no difference. I know the memory is good because it's been in my main system for about a year with no problems.
From my experiments before, I'm pretty sure that I have to leave the latency settings in the BIOS on auto by SPD. I'm thinking that for the new memory, it must be picking settings that are too low and crash the computer when overclocking. With the old memory, the default timings were so crappy, that it was ok when overclocked. Or at least, that seems like what's happening. Maybe the BIOS does something special when you use 4 memory modules. Maybe they reduce the timings or something to make it more stable.
Anyway, to sum up, I'm surprised. This is the first time that I've ever seen a system that will overclock *BETTER* when you use more sticks and crappier memory. Usually, it's exactly the opposite.
hello guys!
dothan is awesome.
i have this config atm:
- p4c800-e dlx w/ vdrop mod
- dothan 740
- 2x512 ocz plat rev 2 (tccd)
what's the better bios and setup for this memory?
thx guys
umbro
Hello eveybody!!!
I'm almost sure nobody's going to see this post, but anyway, I have to try it.
I'm looking for the 1009 beta 003 bios for my P4P800SE, but it looks like it had never existed... every link I find is empty...
Does anyone of you have this? Can you email it to me?
Thanks in advance for even reading this...
@odefruto
Wellcome to XS!!
If it is good in 1009-004 or 1010-001, there are...
:nono:
this beta bios exist and runs on my rig at the moment!
http://img293.imageshack.us/img293/7...tledin2.th.jpg
Thanks for the wellcoming...Quote:
Originally Posted by OMEGA3
I don't know what you mean with this... My english is very bad and I don't understand...
I'm looking for 1009-003 because I've read of the unlocked multiplier, but I can't find a valid link.
Does these bioses also have the unlocked multiplier?
pvhk, can you please email me the bios? xxx@xxx.xxx
Thanks you 2 for all...
Originally Posted by odefruto
Hi odefruto,
Yes,1009-004 can change the multiplier.
1009-004 also have unlocked multi.
I have 1009-004 now, please tell me if you need this.;)
Using now my second-PC at 1009-004, P4P800SE, M750 with CT-479.
Now working 200x12 @2.4GHz Vcore1.28V.
In BIOS,
Advanced→JumperFree Configration→Mobile CPU Ratio.
Can change the multiplier with this menu.
Cheers!
Hi Omega3,Quote:
That's exactly what I'm looking for... I have a M760 and want to use 200FSB (my memory doesn't like OC) without overclocing too much (I'm thinking of 12x or 13x). If you could email me the bios, it would be perfect... xxx@xxx.xxx
Thanks for all...
Hi odefruto,
OK, I sent to you.
Cheers!
Thanks OMEGA3, I've got it!!!
Hello there,
I'm new to this great site. Look my results with a cheap M715, I'm quite happy so far. No way to get above 168Mhz.
good for a 715.Quote:
Originally Posted by micheld1
whats the rest of the configuration?
P4P800 bios 1021.006 (beta)
2x512Mb DDR PC3200
Geforce 6600 256Mb
Disks: 2x200Gb & 2x300Gb all SATA
Plextor PX-755A
Lian-Li PC60
XP Pro SP2
Any way to get this mobo higher than 168Mhz?
Hi again everybody.
I've another CT479 and I can get an almost free Celeron M430, I think Celeron M4xx series is compatible but I'm not sure.
Do you know whether it is compatible?
Thanks.
Lately I discovered that a 0501 BETA BIOS is available for P4GPL-X motherboard. Since I have two P4GPL-X boards running I'm interested whether the BIOS has any benefits over the official 0401. Anyone who knows - please post!
As a sidenote: Celeron M4xx srs uses the same rewired socket as Core Duos. Thus I believe that it will not work with adapter.
Thanks 459, after what I've read, I think you are right. M4xx are Yonah instead of Dothan based, and I don't think they are supported by CT-479.
Hello, there`s a way to get more on those 7x5 CPUs, Kamerat on this forum got some celeron way beyond that too (it`s the same trouble with the Celly-Ms and Pentium Ms that are 100FSB stock). Some soldering to the 3.3V are the way to go.Quote:
Hello CT479 / XS Community....
First sry for my bad english.... i will do my very best to explain my problem.
First my System facts:
P4C800 Deluxe Bios 1021.005 Beta
2x 512 Winbond BH5 (Twinmos)
Pentium M 740
I found the CT479 Mod by Hipro in this forum.
Cause of my miserable soldering knowlegde, I buy a ready-modded Adapter.... Hipro Mod + VCCA mod
And thats my problem:
with my unmodded adpater, my system can boot with 210x13= 2730 (it wasnt rockstable at all, but 24h prime stable.... very rare reboots or freezes)
VCore was in BIOS @ 1,6V (CPUz 1,576)
24/7 settings: 201x13 @ 1,376
Now with the modded one, the highest clock is under 203x13=2639 @ 1,576V
And i have to increase Vcore to 1,475V for my 24/7 settings.
What did I wrong?
VCCA is on 1,931V.... should I adjust it to 2,2v or higher?
Neither adpater FSB nor RAM are the limited factors.... I tested it with lower multiplier an divider.... so the problem must be on the adapter... because the CPU boot at 210x13....
Any details or ideas?
I hope you can help me....
In last consequence, i have to rebuild my system with the unmoedded adapter... but i hope it will be not necessary
Greez loopy
UPDATE: my settings @ time are 201x13 @ 1,408V => reboot.... "Head => table"
Try to reseat your heatsink. It may be overheating. Also, did you perform the Vdroop mod for the P4C800-Deluxe MB? Your cpu may not be getting enough volts to go up that high.
My P4C800-DLX had the vdroop mod which made the system very stable. I was also running a Pentium M 740 @ 2.9 GHZ. I'm running on a non-modded adapter.
I think it's time to revisit the Dothan again! :D
my temps are very ok.... idle 28 and load 34.... cooled by a sonic tower @ sandwitch
my board is complete unmodded....
but it makes no sense.... same settings, same hardware (excluding the adapter) so i have to search the mistake on the adapter.
with my unmoddded adapter i can boot with 210x13 and 1,576V Vcore.... with the modded it dont work... same board ;)
any other proposals??
Thanks....
Up the vcore to 1.6 or a little more. I had to set it at that to boot at 220x13. The drooping in the MB made it unstable for any power use (CPU @ 100%) until I performed the vdroop mod. Also, make sure your PCIE frequency is also set to Target FSB/2.2 to stabilize the system. Mine is set at 110 right now.
Its a AGP Board ;)
PCI/AGP is fixed..... I will try CT479 Jumper @ 400....
Has anyone done a successful S3 sleep and resume with their CT-479/Dothan setup? Seems S3 resume can no longer be done. All I can find is someone else asking the same thing sometime back,
http://www.motherboardpoint.com/t210...m-adapter.html
S3: OC failure and then 3 times on-off ??
I have done it.... very often.... Board P4C800 Dlx... 1021.005 BIOS
Did I get a lousy chip? I have a 740 on a P4C800 with the latest beta bios, allowing mem dividers and vcore adjustment, but I only get 2460mhz stable on default vcore - but I do not get one single mhz more from raising vcore. Cooled by a CNPS7000ACU @ 5v.
Mem divider used so this is not my PC3200 sticks making trouble. My not very impressive overclocking result could of course be due to a bad chip, but since i max out at default vcore i suspect there is something else that stops me from pushing the 740 further. Any ideas what that could be?
EDIT: If i exeed the speed described above the board freezes @ post screen. This also happens if i use lower mp and higher fsb to get past ~2.4 ghz.
A lot of dothans get stuck at ~2.4 ghz
Man that sucks. I am trying to get my HTPC to playback hddvd/bd and my laptop has just donated its Dothan for the purpose - and i think with 100-200 mhz more it would play smoothly.
Funny thing is that it reaches its limit @ stock vcore, and it will not go one single mhz further with more juice. Never seen that on any chip before.
I guess my laptop is will get its cpu back and my HTPC will soon be upgraded with a cheap Asrock mobo and an E4300.
Well this bios/mobo combo allows for vcore adjustments. Cpu-z verifies that vcore actually changes.
I doubt anyone reads this thread, but i have to share my "failure".
did the vcore and vdrop mod on mbo, have already adapter full modded, and even with 1.8V my 740 it isn't stable (i cannot get to desktop, boots wins, but freezes at welcome screen) at 2796MHz (233x12)... and fsb wall is at 238...
I'm very disapointed now:(
To put or not to put more V's? Now it runs on 1.66V 2760MHz, and is unstable on 213x13 even with 1.75V...
