Ok, I will try other drivers. But that delta thing, is it dangerous to my graphic-card?Quote:
Originally Posted by snakeskinner
But I don't have an account on the orb, so I can't see what drivers they are using.
84.21 gave me a lower score. It gave me 8.9k with 580/1830 and X2 3800+ 2.6.
This is my 24/7 settings...quite a nice sore i think:)
Which drivers are you using vocch, I only get 10696 shown below using 84.21 :confused: :(Quote:
Originally Posted by vocch
http://i16.photobucket.com/albums/b2...05681-9212.jpg
That is a sad score compared to mine at lower clocks......what drivers...now that would be telling:) ....nah let us know how they do for you.
MSI NX7900GT 84.26
Edit: Just noticed they are the original drivers for your card.
A quick search on the orb of the highest 7900GT scores with FM approved WHQL drivers shows every score on the first page with 84.21 drivers, including mine :) I went through the first 4 pages and they were all 84.21 drivers. Maybe that is the highest driver that is WHQL and FM approved, I dunno.Quote:
Originally Posted by Zyprex^^
If you search for all drivers, 84.21 is still on top. But 84.25 shows up a few times as well.
The delta thing will not hurt your card. Its kinda complicated, and I don't get it all, so I can't explain it that well. But there is more than 1 core clock speed on your card. When you adjust the core clock, the others are automaticly adjusted to match. You can see all these clocks if you use rivatuner with the 7800 cards, of course this doesn't work for the 7900 cards yet.
The geometric delta clock adds a certain speed to one of the clocks. So if you set a 40mhz delta in the bios and set your core clock to 600 with coolbits, your core is actually running at 640mhz, which is 600+40.
What I usually do is set the delta to 0 and overclock the card as far as I can. Then I start adding delta in small increments to see how high I can get it. With my 7900GT it was 724mhz plus 40mhz delta.
Hope that helps, but like I said, I don't fully understand it all myself. Maybe someone else with better understanding can explain it better.
Marlon
Thank you for taking time to help me:) But where du I find delta in bios?Quote:
When you open up the bios in nbitor is is the clock usually 0 - 50 on the gt/gtx's that are right across from core clocks and before the memory clocks.
Where can I download nBitor? I don't find it in google..:S
mvktech.net is who releases nibitor. You can download the latest version, 2.8a here.Quote:
http://www.mvktech.net/component/opt...rent,category/
There is also a very usefull guide on mvktech.net that walks you through using the program.
Marlon
Thanks, but where are my BIOS file that I must open?Quote:
Read the guide, it tells you everything you could possibly want to know, and even a bit more.Quote:
With cpu@2.830 scored 10845... card same as above:)
http://jvidia.no.sapo.pt/Images/Benc...6-920_1.5v.jpg
84.21
1,5vmod
Tried the 84.26 but score was even lower :confused: so tried 84.30 and gotQuote:
http://i16.photobucket.com/albums/b2...05701-9212.jpg
:D :D
Thats more like it....i think i'll give em drivers a go and see what i get:)Quote:
Originally Posted by alpha0ne
Edit:Here's the results:D
The BIG 11K acheived with a standard 7900gt1.4v@660/1650+an opty165@2750:D :D :D
http://service.futuremark.com/compare?3dm05=1950120
Some optimisations
(i did the dumb with teh screen)
Freqs : 710 / 903 MHz @ 1.5V @ chill -10°c
http://ebola.club.fr/7900gt_3dm06_6794.JPG
Nice :toast:Quote:
I cant understand how you get a higher CPU score tham me though, I am @ 2.8GHz with 2GB memory, maybe the loose timings have someting to do with it ??, did you apply the AMD dual core driver etc ?? cheers
Thanks alpha0ne.....the amd driver was a big no no for me tried it once and had to format my system messed it right up....i tried my cpu even @ 2840mhz still could'nt hit 11k....i could have hit 11k easy if i did 1.5v but 1.4 is my limit.....what did it for me was to drop cpu a bit + and used 166 divider instead of 133...which i thought higher cpu clock would have done it.....well i suppose it would if you clocked it high enough....but more v's no thanks....it was ram speed that gave it that little bit of help it needed :)Quote:
my new score with 1.40vmd , no artifacts yet :D
Opty 148@2990mhz |XFX 7900GT XT (520/1500) @ 1.40vmod@670/880
http://img147.imageshack.us/img147/6736/2k5oc4uv.jpg
3dmark06 same settings as 05 run:)
Sorry of-topic, but is there any lower vmod then the 1.4v?
Yes there is u can add voltage in 0.5V increasments...
Check it out in xtreme graphics mods section ;)
I can't find 0.5vmod, only 1.3/1.4/1.5v. But do the stockcooler handle 1.3v?
http://img401.imageshack.us/img401/6861/mod7by.jpg
