*edited*
I have an 0543TPMW 170 right now, not in my box yet, but soon! Can't wait to be rid of this 0536XPMW...
*edited*
I have Asetek Antarctica block and a water chiller. So far using +6-15c water temp. I must do more insulating before I can use colder water. Load temps areQuote:
Originally Posted by Fluence
20-25c.
I have done +30hours of burning already.
I agree about the 0534SPMWs... nice cpus. :toast:Quote:
Originally Posted by Budwise
Must be blind... can't seem to find this... I just got opty 175 and it isQuote:
Originally Posted by Jeff
CCBWE 0534SPMW
Going to go slow on this one as this is on new mobo A8N32 and I need to learn all the little things on it as well as burning it in correctly for phase change cooling later :) But little pre-emptive view is always helpful... anyone got link... don't know why I am failing to search today.
I just got a 0543TPMW 170. I hope it's better than my 0536mpmw! I'm testing default right now to make sure it's a good chip
ALERT
ALERT
I'm leaving in 10 minutes to picj up a new 3800 X2 at pcclub, is there a stepping or week to look out for? Or to RUN FROM??
thx!! (and no they don't have 165/170/175)
C
Originally Posted by cdelatte
where did you get your cpu from??
My old 3800 X2 was a CCBWE 0529SPMW and did 2600 w/ 1.4Vcore on air... If you can find one that old, GRAB IT...Quote:
Originally Posted by charlie
I have fallen in love with this cpu. Super pi stable 2.4x10 with 1.4v. Time to push it some more :)
I got mine from page computers. Took a little while to ship out so make sure you order at least two day. I order two day shipping and it took 4 ~days to get it.Quote:
Originally Posted by nealh
hi guys,
i'll get an opty 165 CCBWE 0546 SPMW
but i didn't manage to get infos about this stepping
Is Anybody have heard of it?
Thx
KamE38, your 165 has the same stepping as my 170, CCBWE 0546 SPMW, but haven't tested it yet. Any CCBWE 0546 SPMW out there ?
hey :)
hope 4 us it'll be a golden week :p:
hope so :D :D :p:Quote:
Originally Posted by KamE38
I’ve got a question and need a answer before I purchase this 170 opty. There are rumors that these dual core opty’s memory controllers can’t handle much. Will I be able to run 500Mhz 3,3,3,8 on my 2x 1GB crucial ballistixs pc4000? Will I be able to run them all the way up to 580Mhz 3,3,3,8, if the timings are possible on my memory, and theoretically if I can get the clock the core fast enough? Currently everything I got is kicking, but this 3800+ dh7-cg is a real flat tire…:slapass:
YEP! See my Sig.Quote:
My 0543TPMW is doing 2.5 @ 1.36V!!! Dual Priming away!
My 0536 needed around 1.46V to do the same job! Wooot!
Will have final results soon.
Be careful with voltage on that chip...... I've been testing another 170 tonight (I'll have to check the stepping) that runs 2.5 @ 1.23 and tops out at 2.6 @ 1.375 (and the temps go to hell)....... Any voltage over 1.40 shuts it down in an instant........ Looking for the FIRE sale...:) :)Quote:
Originally Posted by phadeout
People are having no problems running those speeds, but that is with the better ram I think. I've seen screens of opteron's running at 280+ mhz on the ram... I think it's more the type of ram/mobo combination, I know some ballistixs can have problems depending on the board.Quote:
Originally Posted by bestmancajun
Well, not this chip... It's running 2.65G @ 1.5V air cooled (see sig as usual).Quote:
Originally Posted by pcdoc1
Been dual priming for the past 10 minutes... 47*C load.
Runs cooler than my old 175, it was 48*C load at 2.6ghz (and a little more volts).
voltage doesn't seem to shut me down, must be you cooling maybe? or bad IHS/Heatsink contact?
Nope it's just a screwed up chip. I've already removed the IHS and tested it in 3 different boards and it does the same in all of them......... You know it's hosed when it does 2.5 @ 1.23... Happy trails. :)Quote:
i took off the ihs and now my chip is doing 2.85 @ 1.65v 35c load from being able to do 2.75@47c 1.62v with the ihs on, the chip is a operton 170 ccbwe 0541rpmw dual prime stable for 12.5 hours didnt test longer
Edited
*edited*
Opty 175 CCBWE 0543 TPMW Running Dual Prime now at 1.42Vcore and 250x10. This chip is not Dual Prime stable at 2.6gig and 1.5 Vcore. Asus Probe temps showing 54C while priming.
54C? what cooling are you running? (obviously not the VapoLS in your sig lol).Quote:
Originally Posted by shogan191
After running CPUburnk7 all night @ 51C and 2.7Ghz 1.5V, this morning at the same room temp it's down to 49C. TT BT and AS5.
Make sure your ram is not running 1:1, I'm having problems with anything above 255 on the RAM, though that will depend on mobo/ram combo and timings of course.
Nope... you're not blind... I am. ;) My chips are CCBWE 0534SPMWs. Sorry about that little mixup. :rolleyes: ;)Quote:
Originally Posted by jinu117
