another bench from my gto² all stock.. voltage and cooling.
Aircooling xp90c + noiseblocker SE2 for cpu
http://img352.imageshack.us/img352/6...30001no.th.jpg
ur score seems low a have 7.1k on 580core and 600mem check ur drivers ;)
I didn't put the XS timings, everything is STOCK
max on air info on the compare ;)
http://service.futuremark.com/compare?3dm05=1490933
The ambient temp seems to be LOW ;)Quote:
Originally Posted by principino1984
How about the room temp?
I have got it into water already, just a quick trial, a bit closer to 8k :D
7928marks on 3D05, the rams are in 166MHz divider
http://img18.imagevenue.com/loc167/th_c64_3D05_7928.JPG
I am thinking of V-modding the card too :D
TerveQuote:
Originally Posted by daysleeper
From where you buy your GTO2 in finland ??
kosmo
Turku
nice score an clocks Tin Tin :slobber:
go for the 8k m8 , il be there soon 650mhz mem :D now 2.47vdd
evilrulez-
you're on 5.11 catalysts?
hi guys is true the later connect3d gtos not being able to unlock pipes???
Mine maxed-out at 651/633 because of not enough voltage ;)Quote:
Originally Posted by blind_ripper
7957marks, still have 43marks to 8k :mad:
http://www.techpowerup.com/articles/...gpu_pencil.jpg
http://www.techpowerup.com/articles/...vdd_pencil.jpg
http://www.techpowerup.com/articles/...ddq_pencil.jpg
No 2B pencil to do pencil trick :mad: :D
seek a pencil and mod the f***ing thing ;)
i need wc real hard now and i run on windows without sp2 :mad:
stil on air last run , im gone stop now
http://service.futuremark.com/compare?3dm05=1499514
now sp2 for windows :(
volts are on the compare , if any say 1.75VGPu is to much for air there wrong :cool:
This card is confusing. Ever since I formatted my idle temp has gone up 7c. I never messed with my heatsink or anything. WEIRD
Hello Everyone :D
Just got a sapphire x800gto runs 570/570 on stock cooler/volts and has the 480 core :toast: (580 core it locked up) (still not tried over 570 mem) BTW its 2.0ns
Now i flashed it 5 times 5 diff bios it says successful everytime but still only 12 pipes :slap:
Am i just going to have to live with 570core/570mem on stock everything :confused:
Another thing this asus an8 sli motherboard does it have hidden settings in bios ? like ctrl & f1 :confused:
Thx Everbody :toast:
i`ve got same clocks on default volt with same card, but i`ve got 1,6ns memory, which supposed to be pretty rare on sapphire x800gto.Quote:
Originally Posted by stestan
I also did my new personal 3dmark01 record:
winchester 3000+@2731mhz
hynix d43 2x256mb @273mhz
sapphire x800gto 650/567
3DMark01 Score: 28562
http://service.futuremark.com/compare?2k1=8809449
stil air http://service.futuremark.com/compare?3dm05=1505889 , if u go higher than 1.8vGpu the ovp wil kick in i have checkt it ant on 1.79VGPU the card gets to hot to bench :( so now im gonne see for wc blok DD maze 4 ;) .
stil no windows xp pro withe SP2 so score lower :(
idle temps cpu and GPu @ 1.75VGPU http://i3.photobucket.com/albums/y90...tempsbench.jpg
I just finished testing of nearly 50 Connect3D X800GTO cards, and I have some bad news to tell.
None of the cards could be unlocked.
Every single card has a lasercut and permanently disabled pipelines.
It made no difference to connect the cutted trace and flash the bios.
ERA of the GTO cards is over :(
You're serious? Are you sure you even used the correct bios and whatnot? I can hardly believe NONE of them unlocked if you did it correctly. But if it's true, sad day :(
Anyone know which cards are still a good bet to be unlocked? Looking for a VIVO card.
Twelve of the cards had the second quad of pipelines disabled/broken.Quote:
Originally Posted by DamienKC
ATITool displayed 0xEFF3BFFF value as DIE_FUSES.
http://www.akiba-pc.com/3BFFF.PNG
Thirteen of the cards had the third quad of pipelines disabled/broken.
ATITool displayed 0xEFF3DFFF value as DIE_FUSES.
http://www.akiba-pc.com/3DFFF.PNG
Seven of the cards had the fourth quad of pipelines disabled/broken.
ATITool displayed 0xEFF3EFFF value as DIE_FUSES.
http://www.akiba-pc.com/3EFFF.PNG
Sixteen of the cards had the first quad of pipelines disabled/broken.
ATITool displayed 0xEFF37FFF value as DIE_FUSES.
http://www.akiba-pc.com/37FFF.PNG
Connecting the lasercut doesn´t have any effect to unlocking the pipelines.
ATITool shows 0xFFFFF71F value as Substrate_Fuses (instead of 0xFFFFF71E) when the lasercut is reconnected.
http://www.akiba-pc.com/3BFFF-71F.PNG
As you can see ATITool reports 0x660 as ROM_FUSES in above picture, so all of the pipelines are enabled by the bios. The other pictures show value of 0x861 which tells that only 12 pipelines are enabled by the bios.
ATI has probably disabled the pipelines internally from the chip. With the current knowledge there isn´t a way to activate the additional pipelines if ATITool reports anything else as DIE_Fuses than 0xXXXXFXXX (X = varchar).
To check if your card has a lasercut or not, start ATITool, press swift, and click settings (only ATITool versions 0.25 Beta 8 and newer support this feature)
If ATITool reports as Substrate_Fuses:
0xFFFFFXXE = Your card has a lasercut
0xFFFFFXXF = Your card has no lasercut
(X= varchar)
I have an unrelated, related questions
1. Are all Connect3Ds r423 ?
2. Are all Connect3Ds 2.0ns?
3. I forgot #3.... hmm... oh well...
I have a C3d gto r423 (noname core) 2.0ns 16 pipes 580/580 on water, but im just curious :p:
Mine connect 3D GTO @ 16pQuote:
http://service.futuremark.com/compare?3dm05=1496230
Does any one have information about Sapphire X800GTO Fireblade - is this card unlockable.
Is it possible to unlock extra 4 pipes with flashing -my Fireblade
10x in advance
Originally Posted by milen_bg
unfortunatly No................
LOL i started this thread and drulled over c3d and gto2 forever, since i couldnt get them in my country. Now when finaly got ahold of them i found out they cant be modded anymore.........i have them comming from distributer in hungary that got them in stock last monday they must be the same batch as those 50 unlockable :( :( :( just my luck
