I've got the same "problem".
My other CPU would just error out in prime95, but this one freezes (literally, nothing happens, mouse pointer stuck etc) or BSOD's. I've only seen it fail prime95 ONCE.
Just curious why you're running such a large divider @ that speed? You should be MUCHMUCHMUCH faster @ 1m @ 2900.Quote:
Depending on timnings and highest ram freq he can use he will be at 28s if he can do atleast 260 2-2-2-6.
260 2-2-2-6? heh i've got TCCD so it's not going to happen
I'm running a huge divider and terrible ram timings because i wanted to quickly and completely take it out of the equation. I dont care what the SP1M time is, i just care that it runs. I'm going for stability, and once i find the sweet spots on the CPU i will bring the ram up in speed and then i'll tighten the timings.
BTW guys, i'm still running chipset at default volts, should i raise it to 1.75 from 1.65? Since i'm working with such high HTTs it should help. But i've never had an option for chipset voltage before so i want to be very careful with it.
raised chipset voltage to 1.75 and haven't had a BSOD yet :)
What program should i use to monitor temps in windows? I tried to get Smart Guardian but it said NF4 only :(
My 3000+ venice LBBLE 0519CPFW that i got from newegg around 6/12/2005 is slow :( .
2350 mhz @ stock voltage
2390 @ 1.425 volts
2411 @ 1.45 volts
2448 @ 1.50 volts
Still testing my A64 3000+ LBBLE 0517EPAW !
http://valid.x86-secret.com/show_oc.php?id=24151
Just a simple 1M SuperPi shot at 3G for now ! Using xp-90 air cooling with a window air-conditioner ! The ambient is blazing hot around here !
http://img279.echo.cx/img279/7471/x9...38p20bx.th.png
PDP XBLK has been tested upto DDR580 @ 2.5-3-3-8 and cpu speed = 9 x 290 MHz w/ 32M SuperPi.
overcrash86 ! Good clocks there with the EPAW :clap: !
gratz guys! EPAW is a damn fine chip.
3 Ghz on air cooling, good job :)
Thanks Man ! But TBH, I really don't know what I can take credit for - that chip is simply awesome ! And I'm enjoying the PDP equally ! A welcome change from my previous rig is all I can say :) !
And this database has been really very helpful :clap: !
Lookin' to go WaterCooling now since temps here can hit 40C !
40C is damn hot bro, where do you live? In NorCal here its just ~75 F average weather. Good luck with teh watercooling. My chip loves volts so watercooling would be ideal for it... but i scrapped my WC plans because i'm moving to a university next year and don't want to have to deal with water cooling when i've only got one 24/7 computer.
HeHe ! Greets currently from India ! But been in hot and humid parts of Southern USA !
Same feelings here about WC ! But looks like I may take the plunge ! Condensation here is a big issue since humidity is very high - live by the shore ! Good luck with the Univ and your latest 0517 !
I received today My new 3000+ Venice 0517 APAW (#0534)
but i still need to receive My Ocz 3200 plat rev2 and My powerstream 520w.
I Hope a New bios for the DFI NF3 Ultra-D release before monday.
TBH, you shouldn't need to raise your chipset voltage to 1.75, especially since you're also running a divider that large. Here's 9x320 (on dfi) 1:1Quote:
http://img262.echo.cx/img262/1359/cropped9x3208sp.jpg
I used the MSI board for the previews of the Venices and I don't ever recall having to up the chipset voltages. Just be aware that too high a chipset voltage can cause just as many, if not more BSOD's ;)
On a side note, while I was flipping through some of my old screenshots to show OPB yesterday I came across one which IMO is pretty incredible:
http://img297.echo.cx/img297/3069/15x2500dl.jpg
The memory was my old G.Skill LE's and IIRC they were @ ~2.8V :eek:
Gah, 2-2-2-7 at 250 is incredible for TCCD memory.
Well i have gotten 1 blue screen with 1.75 chipset voltage now; getting less BSODs than before though so i think i'll leave it there; you would consider it safe right?
I haven't gotten around to tweaking my memory yet but i lessened the divider to 166 so at least i'm doing DDR520 and i changed timings to 2.5-3-3-10. So they're not completely terrible anymore.
DFI is giving me sloppy Vcore like my Neo2 did; CPUZ reports between 1.520 and 1.552... keeps changing! Better than Neo2 anyhow; Neo2's Vcore would change a little bit every time i rebooted : /
BTW, s7e9h3n, what do you recommend for temperature monitoring on NF3 Ultra? MBM5 doesn't have this mobo listed and Smartguardian is NF4 only.
Time to change your PSU ;) I know it's not for everyone, but my modded Zippy700w is able to hold every rail within .01V FULL LOAD. It's simply the most awesome psu I've every come across...PERIOD.Quote:
I forgot what MSI's utility is called, but that's what I used when I had the neo2 running:
http://img60.echo.cx/img60/2687/10x2908ww.jpg
Ah, i thought the fluctuating Vcore as reported by CPUZ was a mobo-related problem, so it is the PSU? My Enermax noisetaker is brand new; it was recommended from a good source. It shouldn't have any trouble handling my stuff... 2 HDDs, 2 CD rom drives, 3 case fans.
The MSI utility is called Corecenter (like it says :)). I used it when i was using my Neo2 but it reports bad temps. My 0515APAW with low volts reported as ~46C Idle and as soon as i started running prime95, it instantaneously went up 10 degrees. Once i restarted the computer and Corecenter reported completely different temperatures. ~5 degrees lower idle and load. It was almost random.
IIRC Enermax makes a few versions of their 485W psu. Does yours have 2 12v rails? If so, get rid of it. :p: If you decide that you need another PSU, drop me a PM, I may be able to help you out there ;) (It doesn't hurt that you're local too)Quote:
That big jump in temp is normal for most Venices. And Jinu117 has noted that his 0515 APAW reports higher than normal temps as well. Personally, my 0515APAW didn't seem like it was running too hot, but then again, it was under phase change for most of the time I had it :p: MSI's temp sensor is kinda buggy but at least you'll have a general idea of how hot your cpu is and Corecenter also allows you to push your Voltages past the bios limit. Just don't try to OC using core center's feature. It's MUCH more stable to use clockgen.....
2.81 seems pretty stable, didn't have enough time to run Prime95 any longer
probably my 24/7 settings for this chip, probably less Vcore after burn in
http://img.photobucket.com/albums/v7...olute035/2.gif
Not bad, not bad at all.....it's nice to see these chips working out for more and more people.
My PSU died on me the other night and so I'm on the family comp. Talking with Andy about RMA though, so hopefully I'll be up and running very shortly. :)
@ Cornelious
Dead PSU, sorry to hear that man. Hopefully you get it back soon.
You check the batch # on your APJW yet?
I just did over 2 hours of prime95 at 2.86 Ghz
http://img.photobucket.com/albums/v7...35/beach/2.jpg
this is with the side of my case off and a big fan blowing in... max temp 52C
Hey guys, I don't know, but my CPU seems to be the rare one as noboy has it but me, or at least nobody says they have it.
Mine is a 3200 Venice with stepping 0517GPBW. Nobody has this stepping and I did a search on the net but nothing came out either. Is this a rare one or what?
Well if you didn't come up with anything i doubt my searching is going to yield much more. So i guess it's rare.Quote:
Originally Posted by jcniest5
But more importantly, how's it clock?
Here's a suicide
I didn't get any crashes so i'm not quite as the max, but i didn't go any further since i was on the brink of locking up...
http://img40.echo.cx/img40/6974/297ghz0iw.jpg
Might be possible to do 3 Ghz but not for today...
Captain, she needs more volts!
Well, now that I've started to talk about it, there's another user's on this forum that he has one like mine, too, but it's not OCing good at all. So, that means it's a rare CPU, a bad one that's why it's rare, not rare in term of being special in that matter. I am running it at 9x290 (5:4-DDR333) with 1.525Vcore. I've tried 245 1:1 but it's not stable, so that shows it's not a very good OCable CPU. :mad:
i certainly expected more out of a week 17
My 0517APJW batch# 1127 is stable at 2.81 Ghz with 1.54 volts and 2.86 Ghz with 1.58 volts. And then 2.72 Ghz with 1.42 volts if you want to scale it back that far.
At 2.81 Ghz i'm breaking 50C so it's warm but i think this will do as 24/7 settings.
after burn in i hope for less Vcore
For all you air users, what would you consider the maximum voltage for good air cooling (xp90, 7700) for 24/7 settings? And for running SP2004 overnight?
I can do more if i go over 1.6 volts but i'm hesitant to do so. I saw one post where someone primed overnight at 1.64 volts on the zalman, wondering what i could do with 1.64Volts heh.
Suicide air shot earlier tonight just for fun. Voltage was 1.600v in CPU-Z :D
http://valid.x86-secret.com/cache/24457.png
http://valid.x86-secret.com/show_oc?id=24457
Muhahah gotta love my noname pc2100 memory! :slapass: The Gskill is headed to OPB's house for repairs :D
Absolute I would say 1,6v
At least I've been running a winchester at 1,6 for 2 months, but at a much lower speed. In my case, if CPu reaches mid 50's it hangs with a BSOD, be careful with this, and it reaches that temp. at 2800 with 1,52v easily
salu2.
