Very nice el rolio. What size/material is the tubing and what liquids are you using? Which rad?
Looks like the radiator from the swiftech kit.Quote:
Originally Posted by thunderstruck!
Here is a sample pic of my humble rig.
http://i4.photobucket.com/albums/y123/yancm2/newrig.jpg
MCR-220 RAD
7/16" ID tubing (mcmaster klear possibly)
Nice setup el rolio! Btw its that tape on your cpu??
To protect the little capacitors from his waterblock.Quote:
Originally Posted by 187(V)URD@
the capacitors on the face of the cpu can be dammaged if the waterblock tips over. I have experienced this, where my TDX tiped over a little and shorted out on one of the caps, which restarted my machine. The CPU died quickly thereafter.
:woot: sapphire board looks very nice!!Quote:
Originally Posted by xforce
http://i20.photobucket.com/albums/b2...0/2b3ce3a0.jpg
http://i20.photobucket.com/albums/b2...0/2c10a07b.jpg
http://i20.photobucket.com/albums/b2...0/959630a7.jpg
http://i20.photobucket.com/albums/b2...0/b91e58d4.jpg
http://i20.photobucket.com/albums/b2...0/87855e0d.jpg
Swiftech MCW6000
DD Maze4 Low Profile
Black Ice Pro
MCP350
Very nice Pied. Top notch components on that SFF.
thanks, means a lot coming from you :)
Awesome work Pied, what sort of temps do you get with that? What fan are you using on the rad?
G
Originally Posted by FragTek
how can u full load your pc...and read the temperature in bios? didnt work^^
According to Everest my load temp on my cpu is about 50C and my vid card 60C. Idle is cpu: 32C and vid card 40C.
I'm using a coolermaster fan. It was something like 22dba with 46cfm
Edit: Everest was mixing my temp up between cpu and mobo. My cpu idles 35C and Loads to 44C.
everestQuote:
Originally Posted by r00t
mbm5
and other similar programs
38*c full load @ 1.67vcore set in BIOS.Quote:
Is that better nubstick?
After cleaning and replace tubing of WC, for now i use Tygon and never buy Clearflex again, tygon is expensive but much better quality....:toast:
Looks nice. 1/2 tubing, right? What mixture are u using?
Very nice geep, I recently watercooled that same case and mine doesn't look at all as neat as that. I'll post pics when it looks more like yours.
I'm also interested in your mixture.
geep, seing as how you have a sound card you SHOULD remove your karajan audio unit. I have heard of quite a few reports of the karajan causing issues when it is installed with a sound card. If you havnt you should also disable it in the bios.
Masterkleer tubing pimps Tygon tubing :p
still a newbie...
not so refine yet.. just installed and ran it as trial... mayyyy make it nicer..
http://tinypic.com/kafhhs.jpg
Thx for the comments :toast:
The fluid is a Coolermaster, same that used WC kits like aquagate and miniaquagate, for now i have good temps. is translucid, anticorrosive, antibacteria, heat transfer, etc.
MaxxxRacer, the karajan module is disable in bios, i only use for keep the dust away from the case LOL :D
Saludos.
And its 10x cheaper! :toast:Quote:
