what overclocking to expect from titan
http://www.youtube.com/watch?v=9UECcmJNPkg
Exactly. SSDs / HDDs / Monitor / Case generally last me until they die, apart from the case ofc which is why my case is the oldest part of my PC. Even my CPU / Mobo are still more than enough.
Graphics cards on the other hand I've been swapping out every gen for the last 7-9 gens, even my 560 Ti SLI wasnt cutting it in games without SLI support. As nice as the Titan is, there will still be a faster card in 12-18 months, no doubt about that. And already there are games that run at <40 FPS on a single GTX 680 @ 1080p.
Yea that was my initial thought, apart from many MMOs that dont utilize multiple GPUs, but then again those run at 120+ FPS on a single 680 anyway. I really wanted to break away from SLI / Xfire and go with having a single high end GPU now though.
guru3d overclock the titan to............1176MHz.....damn :yepp:
I mention this specifically as the Geforce GTX Titan has been designed to overclock. The AIB partners will be allowed to offer voltage unlocked SKUs. And combined with GPU Boost 2.0 you will see this product boosting towards the 1100~1150 MHz range once you tweak it. The reference clock however is 836 MHz with a boost clock of 876 MHz.
However, tweaked... we got it running at 1176 MHz my man.
Don't be so quick to forget that reviewers are getting cherry picked samples.
Just like with all the reviews that showed 1300+ Mhz GK104s, and none of the three I've been through could go past 1250. Also this is the first time ever I've had two cards die so fast with only slight OCs, nothing like what the review samples and lucky peoples cards can manage.
I must have gotten 670s from a faulty batch tbh.
I feel that Inside the Titan core will be like this When you put in your PC:D
http://www.abload.de/img/m_6abff3eaa54da1ec10emiqur.gif
Wants to kill any game:eek::D
My GTX 680's were good OC'ers (1200-1250) while I had them, and my Gigabyte GTX 670 WindForce 3 that I run now is stable for 24/7 gaming @ 1392c/7220m (I run it at 1372c/7110m though so it's not "on the edge" of stability). :D So, some good ones do come out in the wild too.
1200-1250 is plain average lol.
Over 1250 is like 1 / 100. Over 1300 is cherry picked or a needle in a haystack.
Titan will likely be similar, I reckon the average will be 1000-1050 Mhz on them.
http://videocardz.com/images/2013/02...6-1200x990.jpg
DAT.
SLI BRIDGE.
OMFG.
-PB
reality seems to contradict your theory. 7970 came out 12-18 months ago and costs most of what it did then. and it is still the fastest single chip. so that just blew up your theory.
titan will still be the fastest chip next year at this time. and it will still be worth 500-750.
^Erm no. 7970 laugh price 450+ GBP. Current price and after GK104 launched, <330 GBP.... I meant launch price, but laugh price is actually more accurate /autospellcheck win :D
^^ It looks extra nice with those corsair ram modules lurking in the background too. Shame about the fugly CPU cooler though.
yah 1.2v max fan 1750mem 1.2ghz should be doable/sustainable.. or a couple of quite 120mm fans
you worry too much.. reviewers always lower ocs vs retails oced by forum ocers ;)
even cherry picked reviewers still lower ocs :yepp:
Er, no... For example, both GTX 680 and 690 that were received by reviewers were among the best...
That's usually not the case with CPUs since tech process improves and people pump in silly voltages. But for video cards review overclocks are a good indication of what to expect.
Remember, many of these reviewers actually read and post on forums such as this...
Right. Both my 670s maxed at 1240 / 7200. And both died. My 680 replacement does 1228 / 7200.
Forum OCERs showing off 1300+ / 7400+ on GK104s bought Asus TOPs, MSI lightnings or Galaxy SOCs, which use cherry picked GPUs.
Unless the review states that they used cards bought at retail, they are being handed cherry picked cards always. And Hexus did a review on the 670s I had with them straight from retail, and very similar results, couldn't go past 1250.
Too bad it doesn't look like Nvidia is going to release a dual GPU Titan. From power draw perspective that seems like an easier job than GTX 590...
Then again, the price would be ludicrous.
Admittedly I am a bit scared to really push a 1000$ card. It seems reasonable to expect ~1100mhz on water. Even if that is just "average" for XS, it's great for me. :D
by all means guys get more paranoid and get interpol in there.. but dont be so quick to forget youre probably comparing open system vs closed.. idk just saying some reviewers do it on open system.. are you guys pushing max fan max voltage? any extra fan/s to help out? mobos/psus can also make the difference
look what matters is the retails and we shall see
