Yeah, you did, it looks better! :D
J/K :toast:
I don't know about WS, but ordinary boards, like P8P67 Pro I had, were so boring to me. M4E has much more BIOS options to tweak and have fun. :up:
So could anyone give me a hint about what settings to change from auto? Like I've asked before, most settings I change only create instability or the system hangs on lockup. I'm forced to leave everything, but vcore, on auto. :shrug:
here are my volts for 24/7
http://i54.tinypic.com/1ya2vd.png
normally for 2 dimms I undervolt vccsa to 0.9v, but for 4 dimms I raised it a bit.
Also normally for 2 dimms I run vccio at 1.06v with no problems.
llc at 75%, I have both the jmicron and marvell controller disabled since I do not use them.
When you bench, you can load the extreme oc profile, and set voltages from there.
I'll play with that tomorrow and see what's up. I don't want to try anything while there's a lightning storm.
I'm just looking for that extra 100 mhz. Hopefully this'll get me there. :up:
I'll report back tomorrow.
Is the Marvell 9182 6G SATA controller worth using? or should I stick to the Intel? ...and how do they compare, is it much better/worse than the Intel?
(sorry if this has been covered)
Hi
for me the best for my SSD is intel controller
marvell = slow ssd
Hi
i post my setup bios for 5 Ghz on air / HT on
http://imageshack.us/g/32/110612102232.png/
but i can t be stable at 5 Ghz whit 1.40Vcore
if you can post you bios setup , thank you ;)
any news on any new BIOS????
Hi,
My first result with my two vertex 3 ssd's !
http://www.abload.de/thumb/screenshot0014keo.jpg
And here a Review from the 240 Gb Version :
http://www.ocaholic.ch/xoops/html/mo...php?itemid=517
Roger
Maybe it's the chip? I tried those settings. Same issue. Windows sits at the MS Flag screen (been 2 minutes as I type this) and won't load.
Really strange. I can live with 4.9ghz. I'll have to play around with this later.
I do have the SSD on the marvel port, could that be it?
How far u can go with VCCIO?
What is a max recommended voltage for 24/7 without "hurting" the cpu?
Around 1.4, 1.45 max imo.
@RAJA
i have make tests about sata performance on virus scan pcmark05
on same settings with mive and msi marshall ,on mive i cant do better than
1100 virus scan with 3 acards
on marshall seems to be easy 1300.
when i use marvel controller with bclock of 105 circa i have
os corruption
maybe need a bios update for both controllers intel and marvell
thanks RAJA :)
testing a new 2500k, i love this board:)
http://i.imgur.com/nRTu1.png
http://i.imgur.com/UaPgh.png
reflash 1409 bios and problem resolved
I noticed today that the boot led or the vga led were red but only for a few minutes when I turned my PC on.
The led turned off and everything appears to be okay but should I be worried?
Thanks.
