thanks, just flashed F7 and noticed the PLL override setting was gone, gonna try F7E
Np and welcome. :) Nice looking rig, I use the white tubing myself.
Nice looking rig there, Nice job on the sleeving looks like you have experience and not a nooby :)
man sleeving those power cables is something else. really like that
oops think i killed my 2600k , mine needed a lot of v core 1.65 for 5.373mhz and ran all baenchies but tonight i had bsod a few times with something like failure to something signal on secondary processor , now all it tries to do is a permanent boot loop , so everything comes on as though its starting the boot process then clicks off and tries again and again, could be board but i think its the cpu myself
dont take long with that kind of voltage huh glen?
that sucks.
you need a better chip anyways
:D yeh mate got to look on the bright side :up:,can't see it being the motherboard . it tries to post but just loops and nothing on the led panel with the boot codes ,i'll get a cpu to try tomorrow
what cooling subzero? if subzero that really isn't promising.
LOL BTW nice cable sleeving i see them in microcenter for like 5-10 bucks per extension they are sleeved like that, I would do it if I kept this thing in a case. Or if my case had a window. I would do black, when get a gold plated waterblock black tubing, gold plated blocks for my GPUs and so on.
Aver,
If i recall, you *backflashed* the backup BIOS with an older version, is that right?
Maybe the main bios can be backflashed, but perhaps it was backflashing the backup that killed it?
I remember WAY back, with an Abit BH6 board (rev 1.1), they released some BIOS (around the time they broke CAS latency changes temporarily), I think it was version NK, and if you backflashed to an older version, it would brick the BIOS (the dos flasher would reach around 30%, then suddenly "insta-speed" 3x faster up to 100%, then the board wouldn't POST anymore. You could backflash successfully by hot flashing *twice* (the first hotflash would brick, the second one would succeed).
There was a 1.0 board BIOS version which did the exact same brick...I think it was two bios versions after the initial release of that board. I recall posting (maybe on the old ocforums?) about warning people NOT to backflash.
LOL I still have an old spare bios chip abit mailed me from back then...
Has ANYONE here successfully backflashed the backup BIOS with alt-f12 and NOT bricked their boards? (I don't suggest you try it until you get your RMA'd replacement from the recall...)
I've pestered Dinos22 in PM, but i thought i'd post these images here anyway. Is anyone else finding the Marvel SATA 3 ports are giving slow write speeds?
Intel SATA 3:
http://i24.photobucket.com/albums/c1.../Attointel.jpg
Marvell SATA 3:
http://i24.photobucket.com/albums/c1...ttoMarvell.jpg
This is my max overclock for 24/7.
Using L1 4.0v set in bios with everything Auto.
If you notice under load = 1.356v max cpu clock 4.7
System is 100% stable, 30+ passes on LinX a few hours ago.
This time I left everthing enabled turbo ect. Running bios F7
I wonder why they limited Vcore at 1.7? Seems like 1.9-2.0 would be more of an ideal Vcore limit!
Not very extreme is it.... makes me wonder how much further these chips will go as I've just seen one run x58. Maybe its something I have done but my UD5 has no x58 multi x57 is the max you can set.
Edit: Think x57 is the limit of 2500K's ... 2600's go higher just waiting to see one go quicker than x58
There is no need for more volts. If you do need more I can give you a bios for 2.1vcore heh
Sorry I didn't catch that, but ya I have back flashed the backup as well when going back to F3 to test some things (From both being on newer F6x or above)
