and the PNY's goodness cooled by Accelero X+
http://img826.imageshack.us/img826/5...x480900.th.jpg
my gtx 480 inno3d block koolance 1.21 vgpu
http://img80.imageshack.us/img80/6697/mathias2.png
Nice scores
Very Nice CPU oc
Awesome GPU oc
This hack works with drivers I tested 260.99 and 263.09.
9234 - 2 x gtx 470 http://3dmark.com/3dm11/139115
5962 - gtx 470 900/1000 http://3dmark.com/3dm11/155160
【CPU】Core i7 980X@5GHz
【MEM】DDR3-1600 2GBx6
【VGA】GTX480 3Way-SLI @900/1800/2000
【VGA Driver】 266.44
【OS】Win7 64bit
スコア
P15300
Graphics Score 17438
Physics Score 11868
Combined Score 10299
GT1 75.95
GT2 82.54
GT3 111.54
GT4 54.03
PT 37.68
CT 47.91
http://blue.ap.teacup.com/kazukun/img/1293821866.jpg
http://3dmark.com/3dm11/325295
hello
can some1 tell me why there is no double ram gtx 470 and 480? why none of manufactuers didnt wanted to do such cards?
http://3dmark.com/3dm11/385521
P6235 3DMarks 963 core only bios voltage mod
Any new BIOS with high voltage for GTX470? Or any new tweaking utilities to push GTX470?
I use nVidiaInspector ny Orbmu2k to OC mine.
Hello everyone :)
I'll cut to the chase: Does anyone have that Vmem pencil mod done successfully on a GTX470?
I know the vr-zone is trustworthy and I did the OCP mod as indicated, and it worked like a charm. But this pencil mode, doesn't seem to cut it... :/ I tried sereval times, but the Vmem doesn't move at all. And I am a bit reluctant to do a classic vmem mode, with a trimmer - if I have the option of a pencil mod, instead.
I know pencil mods of the past relied heavily on what kind of pencil is used; so check that.
I tried that pencil mod again with a different pencil - no luch again. I'm getting my soldering iron warm... :shrug:
i got Gigabyte GTX480. with default FAN settings temperature in Crysis is 92-94C. all people remember what happened with another hot cards 8800GTX / GTX280, after 1-2 years of using they usually died, and reason was that videochip falls off from PCB, because too big difference drop in temperatures, idle 50, load 90.
What do you think, will be same story with hottest today card GTX480 after 1-2 years?
My 295 died and in summers in India that thing would be sitting at 90+ 95+(In games hours on end) all the time. Friends 8800gtx was the same, the 8800gtx (Evga) is still running in another friends machine playing crysis 2 :P
But with both cards since im the type that cant help open stuff up used to get serviced ( at pretty regular intervals) changed paste on the cards twice in their lifetime didnt have a choice with the 295 the sandwich cooler loved dust.. I feel it depends on the chip you get. Just as some OC better some probably age better with use.
Gonna get a 480 most likely and im gonna slap a ACX on it before I oc it and put it through the usual abuse. Famous last words :P
Anyone know anything about the 470 Engineering cards? I just got two of them and wondering what I can do with them. Will normal waterblocks fit them? What all can you do with engineering model cards?
I received a GTX 480 replacement for my 3rd RMA GTX 295 and I put a Zalman VF3000F on it:
http://www.hitechlegion.com/reviews/...r-gf100-review
How far do you think I should go? I have had MSI Afterburner up to 910/1820/4000 with 2 completed 3DMark11 runs (see link in sig)
Basically do you think I will gain anything going to a hardware volt-mod over software if I'm already breaking 900 on the core? Avg temp during gaming - 60-70C with current OC
