Would like to update my i5-655k.
This chip doesnt seem to scale as well as my other clarkdale chips.
P55A UD6, #L008B538, Water
http://img202.imageshack.us/img202/1...1mhzi5655k.png
Uploaded with ImageShack.us
here is my 920 batch #: 3949A372
http://i29.tinypic.com/sphp3t.jpg
I think I can lower some voltages however 1720 6-6-6-18 feels very nice:up:
^^ Nice job. :up:
Same chip that got me to 6.8GHz back in March.
http://www.xtremesystems.org/forums/...d.php?t=246726
It's been collecting dust ever since. But I just started putting together a new SFX build and dusted it off to see what she could do with ambient cooling :)
This was done with the following:
Gigabyte H55N-USB3 mini-itx FTW :up:
Intel Core i5 670 - L935B898 - 1.525V set in BIOS *LLC disabled* 1.472V at load
2x1GB Crucial Ballistix DDR3-1600 CL8
Corsair AX1200 (total overkill :D)
Water cooling with 21C ambient temp
http://i161.photobucket.com/albums/t...8-21C-372W.png
Thanks :) I've very close to 4.9GHz right now....5GHz should be pretty easy next winter :p:
Oh, and I found the batch # :D
http://i161.photobucket.com/albums/t...n/IMG_8334.jpg
Oh, BTW - it passes fine with the mem @ 1000MHz as well :D
It's obviously the AX1200 doing it :p:
Very nice! :D
Welcome to the new members, and thanks for your submissions, everyone! Good job! :up:
New Linpack libraries for LinX are out, btw. They fix stress testing for Gulftown CPUs.
Just reposting:
I also added a link to the updated LinX distributive (0.64 with the latest Linpack libraries) to the OP.
i've come to the conclusion that i don't think i can get LinX to be 20 pass stable with my system at or above 4.5ghz.
why? because i use 12gb of memory @ 1866 (1880 actual) at the moment... and i think it's becoming too much of a load on the IMC to go any faster. any time i do it'll error out left and right.
but, at 4.3ghz / 1880mhz, LinX is doing 20 passes stable @ 81.7-82.1 Gflops w/ HTT enabled.
I have a 655K which was terrible on LN2, but I'm going to give it a shot with this as well. We'll see how it goes :up:
Quick update to put me at the top of the 2C/4T list :D
Intel Core i5 670 - L935B898 - 1.537V set in BIOS *LLC disabled* 1.472V at load
Corsair AX1200
Water cooling with 25C ambient temp
http://i161.photobucket.com/albums/t...5-25C-380W.png
Nice job, now i have to get back to work with my 660 lol. maybe i need to try an H55 board they are doing very well.
^ he was using HT, i had it disabled for 5ghz, my chip ran 4800 pretty easy on low vcore, i will try it again at 4900 when i get time, but after 4800 it gets a lot harder to pass.
http://www.xtremesystems.org/forums/...&postcount=632
IMC doesn't do nearly as well with 4GB :(
either does mine, I can pass easily with it in single channel however at much higher clocks:)
Yeah noticed that with the duals. My i3 550 runs 4.85ghz with 2gb, 4.77ghz with 4gb and just over 4.6 with 8gb. That's KO stepping mind, my 530's were considerably worse with 8gb.
my 655k did great at 4500-4600 but any higher it scales horrible even with 2gb of ram. the 660 has been very good with 4gb up to 4800mhz, tried last night to go higher but is a real pita, linx stops early and says finnished without error but after only 2-3 loops. i will stop at 4800 4threads, that chip has done nothing other than run linx every time i nstall it for a couple months, it is retired now. would hate to kill a good chip.
small update from me =]
http://img641.imageshack.us/img641/2337/4600.jpg
forgot to change memory timings but passed anyway =] working on 4650 ;]
Congrats man, great work :up:.
