Nice picture for a start! :up:
Eagerly waiting for more pictures of our one-handed hero! :D
taking another crack at i5 750 all night tonight ...
chew went crazy today LOL...we're over 7700pts
someone post a screenshot after he's done posting his scores :D
awesome benching chew
chew is numero uno:party::party::party::party:
Good luck :up:
Great scores Brian! 9th rank global in multi-card 06 with your 965 BE @ 6300MHz core 4200MHz NB is just crazy!! :up:
But: No benchmarks were run with the 2400 XT? I was looking forward to ORB ownage with that card! :D
http://img18.imageshack.us/img18/204...vember24th.jpg
Edit: AceBaran has found some points, almost breaking 20k in PCMark 05! Go for the last 3 points!
That 03 run is not bad either!
Dave, could you please run WPrime on your new toy? :)
chew 2006/2005 single 5970....can be improved...xp perhaps? ..and higher clocks :)
go go go :D
Vista is fine for such powerful cards, you'll lose a bit during the CPU tests but you'll gain more points during the game tests.
I was expecting to see higher clocks on the 5970s too, Brian, can you comment?
If something even faster is coming I will wait. :) In fact the submission would be blocked immediately and would be counting for points after the official release of Gulftown. The same happened with Josh's submission.
I would love to see the CPU score of such a monster! :up:
ei you guys...i gotta ask...do you know some vista/win7 tweak that lets your gpu scores on gpu test1 go high?
on my 8800gts320 on hwbot...1st place guy...has lower everything..and i'm like...whats wrong with my software... i'm sure my oc is stable..so nothing wrong there that pulls my score low...
vantage runs only for now..thanks guys....
http://i24.photobucket.com/albums/c5...ity25/fukk.jpg
He's running different drivers, that's the only thing I can think of. Try the 191.07 version.
And why did chispy report your score, I don't see anything wrong with it.... :down:
i tried different drivers already...same thing...also win7 and vista..i can't figure it out...
its also the same thing with my 295s...some other guys have lower gpu clocks ang yet they beat my high gpu clocks...
some 295s are actually the mars...but i already figured that out...just weird that some can score gpu points so high as compared to some...dunno if has to do with aero..lod...or some program that lowers my gpu speeds...5
example of 295 uber tweak is team.evga johnksss his 295 vantage runs are uber fukced
my scores are ...easy to replicate..so vantage is stable..the videocards are stable...there is some tweaking that some are doing..i'm not sure if lod works with vista/win7 .....
oh forget chispy...he's not worth talking about :D
Day 1 was done at stock clocks on cards with single GPU.....long story. CCC no worka so stock clocks and stock quality, had to flash a bios for day 2.......Cards were on loan......If they were mine they would have been booting at the max voltage the card allows with uber clocks. :p:
Drivers are a tad immature still as well.
Tnx Don_Dan
Im hitting a wall atm.. cant go anything higher then 201x21 if i try 202 no mather how much volt i increase i cant get it to be stable
Maybe if i downclock my ramm more i can hit 4.3 couse my temps are hitting 85 allready :/
Advice is welcome :)
Nice runns there Chew !
lower you cpu multi...just for bclk testing...
do 202 bclk and say x20 multi....try vtt at 1.4v....
if this won't work...you'll have to use a higher multi to attain high clocks...
vtt voltage affects core temps alot...remember the imc is on the cpu....
awesome pcmark05 score at 20k
Weird, the only possible difference can still be LOD, have you tested different values yet? Might be worth a try.
johnksss' runs are great, 16th 3D Vantage global on chilled water is not easy.
I just compared his runs to the ones around his scores, it's so extremely tweaked.... He can easily make up for an extreme lack in MHz by some other tweak. I wonder how he's doing that.
I have to admit, my experience with 3D Vantage is rather limited, the only time I ran it was on my laptop, and while I'm holding every WR for the 9200 GS, someone managed to beat me in this benchmark with lower CPU and memory MHz....
Will you get some cards for yourself? So you can torture them properly? :D
Could also be related to PCIe clock. Have you tried higher clocks, 110-112MHz seems to be the sweetspot from what I read, though I'm sure the i7 guys are able to help you out.
Winter will hit Europe soon, just get your PC outside and solve your cooling issues! ;)
if all goes well tomorrow i should be receiving 15L of Liquid Nitrogen.
Will be running with my W3540, trying to do superpi 1M / 32M , Pi_Fast and both Wprime's.
Cant wait!
Have fun and make some great runs! :up:
You guys might want to check this out, upcoming changes at hwbot.
