love to see that running IBT or linx ^^^^
I'd give it 1.3 seconds before a BSOD.
What are the chances of D0 doing 4.5Ghz stable? What's the average voltage required? I wouldn't want to spend extra cash if there isn't a lot of difference from my C0.
3845a935
anyone seen anything on a 3850a823
its a W3520. Won't be able to test it for at least another week.
I know no guess is perfect, but i'd like to know what i can on it
I am trading someone my c0 and some cash for his d0 is is a 3849A916 batch I heard this batch does very well. I have seen some benchmark it at 4.5 Ghz on a Giga board. So far my C0 will top out at 4.2GHz, hope this new chip is worth the extra cash.
my B027 is pretty good, so I'd go with the B028
http://valid.canardpc.com/show_oc.php?id=587080
Hello anyone, planning to upgrade-anyone heard, had this batch , pls ? Any info, any feedback on this ? Thanks ....:)
Prime blend is harder to pass than IBT or Linx. Although 2 hours isn't much I have been through 3 different processors and 2 different sets of ram and have always needed 2 extra notches of Vcore to pass Prime blend after I was Linx stable. Also have spoken to others that have much the same results, however have never seen anyone post screens of prime blend 8 hours at the same vcore as linx. Care to take the test?
On water with HT off it's a comfort zone for my 920, I can do it with HT on and can do 4.6 with HT off 24/7 but the temps are so much higher that it just seems past the point of diminishing returns for a 24/7 setup. 4.5 HT off is nice temps don't go above 80c usually hover around 70-73 on a 24 hour Prime blend.
It is hard to make a global statement based on a few samples, and apply that to thousands and thousands of other setups, sometimes you can be right...and sometimes not. Took me just few hours with linx to find below OC points, and have checked some with prime, and like on my i940 I record tests.
4.2 HT on, vcore 1.28 pass linx 10 runs of 5100mb, 2 notches less fails 1st pass.
4.3 HT on, vcore 1.31 pass linx 10 runs of 5100 mb (max memory), 1 notch less failed 8th run of same, later confirmed 9 hrs prime stable blend.
4.4 HT on, vcore 1.34 pass linx 10 runs of 5100 mb, 1 notch less failed 6th run, confirmed later with 9 hrs prime stable. Lowered vcore 1 notch in bios, still says 1.34 cpuz load, and still passed prime 13 hrs.
4.5 HT on, vcore 1.38 pass linx 5 runs, 45 mins prime, did not run either longer 2nd temps.
On both my i940 and i950 I need at least same and when tested more vcore for linx at max memory, than prime.
Showing a prime blend and linx stable screenshot together, how would you know they did not simply choose a vcore that both would run at:shrug: I have a 13 hour run with prime blend at vcore that failed linx max memory.
Only way to prove anything would be to video a 13 hour run of prime at vcore where prime passed but linx failed, then keep video going and run linx and capture the bsod. But time demands vary considerably from my interest in the subject.
Since I have now heard quite a few arguing both ways, I assume it is possible for some cpu/mobo/setups to need more vcore for linx or prime, especially given difference between 2 programs and given extra heat of linx.
Or maybe I should get into the internet spirit, and say everyone is crazy that found it the opposite of my setup:D.
Just starting to overclock my W3520. Stock voltages, but boy these things can get hot, even under H²O.
http://img197.imageshack.us/img197/284/37801152v.jpg
LOL I know I pull my hair out every time I see someone claim you can't pass linx when you have a Prime blend stable 8 hours or more. It drives me crazy because it has never been the case for me Linx is rough on temps but easy on stability it is roughly equivalent to Prime small FFT's in my experience and that's with 3 different processors and 2 different sets of ram. Also 2 different mobos... It's not that I don't believe anyone It's just that I would love to see some screenshots showing otherwise to satisfy my curiousity because in my experience I just don't see how it's possible and i've never seen anyone post screenshots saying otherwise so I continue to believe it's not possible.
I don't think this debate will ever get solved though even with screenshots, because there will always be people to claim otherwise :)
