Oh ya sorry its not actual voltages. I dont think there is a sensor for vdimm on these boards.
From 1683Mhz the next step is 2100Mhz.
Since UCLK needs to run at twice the speed of RAM, you need UCLK to run at 4200Mhz. Not all CPUs are able to do this, and certainly not on air.
You are already at 1.37v QPI/DRAM, and since its not recomended to run over 1.35 for 24/7 I wouldnt try to solve the problem by increasing the voltage.
It might also be that your RAM needs additional voltage, but since it wont even boot, my money is on the UCLK/Uncore. (1.65-1.7 is max recomended for 24/7)
Or, maybe the AUTO setting on DRAM Timing fails, and is running to tight. Try running Manual instead of AUTO and make sure the DRAM Timings are 9-9-9-30.
You should try running 21x multi (191x21). This way you can run 1900Mhz on RAM and youŽll only need 3800Mhz UCLK.
If you really want 2000Mhz, you need to increase BCLK to 200 and either run 20x multi or 4200Mhz on CPU (200x21).
Be aware that the 20x (all even multis?) usually requires higher CPU voltage than 19x and 21x (all odd?).
Any place I can go to add a bunch of stuff to OC Palm and make it half as useful?
Also, I hope they come up with a fix soon. Running Quad-SLi, sometimes it can't decide which is the correct video card and makes the bottom one primary, so I have to shut off and turn on like 5 times until it realized that top one is primary.
Hi all,
Does anyone know where I can get the Enzotech MST-73 and the MST-88 for the P6T deluxe?
Anywhere is the UK or anywhere that will ship to UK?
Just ordered a MIPS NB/SB waterblock but don't want to put the mosfets under water.
Anyone got any other solution idea?
Cheers guys
A little question..can i use a X5550 cpu on my Asus P6T Deluxe v2? or it's only working on a dual socket system?
Thanks,
JP.
Okay.
here's my try.
this is the achievement i got and i think it's good so far,, but really i don't know about the heat.
i think 81c max is safe at 100% x8 load!??
here is the pic.
LinX test.
http://img194.imageshack.us/img194/9434/77159513.jpg
the droping in GFlops score cause i was using windows.
Prime95 Test
http://img189.imageshack.us/img189/9610/24630779.jpg
http://img200.imageshack.us/img200/1778/27727790.jpg
and this is my Bios Setting
your thought.?Code:CPU Ratio : 19
SpeedStep : Disable
BCLK : 206
PCIE : 101
DRAM: 1651
UCLK : Auto
QPI : Auto
DRAM Timing : 8:8:8:16
CPU Volt : 1.20625
CPU PPL : 1.80
QPI/DRAM : 1.26075
IOH Volt : 1.18
DRAM Bus : 1.66
CPU Differential Amp : 800mV
* Skew : Disable.
CPU Tm Fun. : Disable
A20M: Disable
SpeedStep : Disable
left is auto
Yes. But more options is lock in bios, not only when working with Xeon:
http://img39.imageshack.us/img39/1153/37285791.jpg
For my xeon I buy EX58-EXTREME:
http://img6.imageshack.us/img6/3912/x4500.jpg
http://valid.canardpc.com/show_oc.php?id=577039
http://img6.imageshack.us/img6/3519/x4000.jpg
Now I`m happy:up:
I need some help with a friends build I am doing on a V2 board. For some reason I can not get the 2 x DVD-ROM drives to work, or show up under MYCOMPUTER? I am running 2 x 300GB WD VelociRaptor in a raid -0- with 1 x WD 640GB storage drive. All HD shows up fine but for some reason I can not get the DVD-ROM to show up? I am running BIOS 504. I am also running a 920 CO batch as of right now NO OCing just stock settings... If someone has any quick ideas would be great, I need to finish this build and give back to him. I think a SATA PORT may be dead. I ran a seperate line to my DVD-ROM and I smelt a electrical burning smell and shut system down. Has the V2 board ever had problems with the SATA PORTS like this?
http://i274.photobucket.com/albums/j...n/IMG_1643.jpg
Found the problem 1 dead SATA PORT oh well I guess no plug in for the front panel sata on the case.. Just happy I found the problem now I can start the OCing fun...:yepp:
CPU header is fine. But, I think chassis fans 2 & 3 are going. The will not work on boot. Ten, may start for a while and stop again. I keep Q-Fan Disabled. But, I turned them on an off and flashed the bios with no luck.
The PDF said max 84W. I think I using 8.64W. Worked fine for many months.
Think my board is damaged?
http://chuckbam.com/i7_P6T-D/Therl011609-2.PNG
New bios for Asus P6T Deluxe - 1605
ftp://ftp.asus.com.tw/pub/asus/mb/lg...ELUXE-1605.zip
For my YES. Full support for Xeon:
http://img3.imageshack.us/img3/3131/x4000l10.jpg
Bios is very rich of options.
Extreme because no UD5 when they shop:)
nice, so if I wanted to run only air cooled on this Extreme version is the waterblock going to be a problem or does it come with a separte heatsink to swap out the block? and how hot does your VREG get when you were running LinX? :)
Ben,
I had this Gigabyte Extreme in the past. This board like Asus is very cool, it stay warm @load, no need for air cooling or WC on the NB, maybe only if you go SLI and don't have good airflow in side.
I know you don't like eVGA X58 SLI if there VREG high temps when @load, so you will be very pleased with the Extreme or UD5. From what i remenber the only 'weak point' of Gigabyte X58 boards was the slow boot when you power on the first time.
