Read it better. He's laughing at his own mistake. :shakes:
less BS more Xtreme ; 0 :welcome:
Hey there!
Well, strange things happen every day and today was one...
First things first, I love this chess simulation. It really loads the cores 100% (reported usage never fell below 99.2% on any of the threads, averaged around 99.8%), it is more representative of real life than Prime or any of those other things, and it really generates maximum heat on all cores. So, now that I am done praising you on to my testing...
I decided to give your program a whirl to see what kind of results I can get. Naturally, anything with 20x multiplier was a no go so I tested with 200x19, 212x19, 216x19, and then finally tried to do 220x19. Well, all went very good until I got to the last test. I upped the volts in BIOS to 1.5V vcore, 1.475V-ish QPI/DRAM. I booted, ran for a couple of seconds, then my computer just shut down and I could not reload into Vista. I ended up having to pull the battery on my R2E :eek: and manually restore BIOS2 to BIOS1. After doing that, I reinstalled BIOS 0804 to BIOS1 and for the first time since I bought this board after updating the BIOS the board actually rebooted itself successfully and prompted me to set the new BIOS settings! Whoa! :shocked:
It gets better. So I decide, what the heck, I do not have any of my profiles any more, how about I just set X.M.P for memory (sets DRAM voltage to 1.65V and QPI/DRAM to 1.35V), leave all timings as is, all other voltages to Auto and set the BCLK to 200 and multiplier to 20x. I booted, started your app, ran it, and crashed about 4 minutes in. I was like "crap, here we go again with the 20x multiplier" but then I remembered reading somewhere that somebody said QPI/DRAM voltage should be always no less than 0.01V and no more than 0.03V away from vcore. So I grabbed my MM, measured the vcore voltage, then set the QPI/DRAM volts to be exactly 0.025V apart. Booted back into Vista 64 with the new settings, ran your app, and no crash! None, nada, it keeps going strong! I stopped it about 15 minutes in just because it had already stabilized on load and temps 5 minutes prior to that. Impressive! :shocked: It looks like I at least managed to find something that makes 20x multiplier work.
Anyway, here is the screen (I forgot to save results)...yes, I am sure the volts can be lowered, but quite frankly I do not care at all. I am using all auto except X.M.P profile and I have manually upped the QPI/DRAM from 1.35V to 1.40V. Cooled with a CoolerMaster V8 using AS5, in a toasty 23C room with the computer stuck in a corner where there is barely any airflow :p
200x20 baby :up:
ummm, R2E bios 0804? where??!?
edit: nevermind, found it.
Lol, I was just about to post it...
http://vip.asus.com/forum/view.aspx?...Language=en-us
Yay! Improved RAID controller compatibility... Grrrr.....
pfft. :down::up::shrug:
That damned scratchy wool mod hat..
Ok guys, calm it down or do I have to play Attilla the Hun here?
try a little patience and when you fingers want to type something nasty go get a cold drink and cool down before you post.
No one is perfect so if and when someone says something that isn't quite right cut them a little slack in your reply.
remember, no matter how smart you are or how much you know there is someone on this forum that knows more and is smarter.
Now friends first huh?
Thanks for reading.
Well said.
Anyway, with the new bios and realizing that I only had 2 of 3 fans running on my rad, I am running prime for about 25 minutes @ 4.2 with a 21 x 200 @ 1.41250 and a vtt of 1.53750.
Temps are 80c solid under load and things are looking good.
Typical ASUS you shouldn't buy their boards if you need tech support from ASUS for real.. We are all aware that there tech support is a joke but there boards and bios updates are no joke... In addition there is a new bios out for the P6T Deluxe bios 1003 you can get it here:
ftp://ftp.asus.com.tw/pub/asus/mb/LG...ELUXE-1003.zip
here's 3.6Ghz 20x180 8 hours prime blend 64bit stable with 12GB of ram.
edit: using the Z18 bios. temps are 68C, 68C, 67C, and 67C on the cores.
i stopped prime after 3 hours last night @ 4116mhz HT on, turbo on, vcore 1.45v, qpi/vtt 1.435, dont wanna push it more till i know more about voltages, i still wanna see what clocks i get with HT on and turbo off, then HT off and turbo on and then HT off and turbo off
mine is the same , hates 20 x multi, but i think they just need more voltage hope future bios will be better for us
i agree 100%
whats the longest you have run prime at and at what voltages and clocks, most of your prime screen shots that i have seen havent been very long, sorry if i have missed them,
stable to me is at least 8 to 10 hours of prime even longer, as i have failed prime even after 3 to 4 hours before
cheers guys :D
Hey, quick question as I've been away from the discussion for several days. Who has gotten the highest OC thus far without volatage increases? I've been wondering if one of you guys with those "golden" chips that OC like nuts ever tried that out.
I tried again last night and can't get a 20 multi to work at anything reasonable. Oh well, I guess I'm stuck until possibly another bios update.
Yeah the 1003 bios for the P6T Deluxe doesn't seem to fix the 20 multi problem either.. Seems so strange that I can rock 210 or 211 at the 19 multi but can't do 200 at 20...
200 x20 is working fine here. Maybe its a per chip thing?
Same here. In fact, if anything 20x200 is more stable for me than either 19x211 or 21x191.
giga x58 ud5
patriot 9-9-9 DDR3, 6GB
i7 920, 'C0' revision
Tuniq tower 120
Yes, with HT either on or off.
