I got cha I changed that around now to 100 MHZ. I backed it down to 3935GHz for now but here some LinX from 4131Ghz temeplate for 4131Ghz whe.I had it up there for a week running smooth
Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..................: Auto
CPU Clock Ratio ..........................: 8
Fine CPU Clock Ratio......................: +0.5
CPU Frequency ............................: 4.13Ghz (486x8.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control....................: [Enabled]
CPU Host Frequency (Mhz) .................: 486
PCI Express Frequency (Mhz) ..............: 100
C.I.A. 2..................................: [Disabled]
Advanced Clock Control
CPU Clock Drive...........................: 1000mV
PCI Express Clock Drive...................: 1000mV
CPU Clock Skew (ps).......................: 0ps
MCH Clock Skew (ps).......................:50ps
DRAM Performance Control
Performance Enhance......................: Standard
MCH Frequency Latch......................: Auto
System Memory Multiplier ................: 2.00D
Memory Frequency (Mhz) ..................: 972
DRAM Timing Selectable ..................: Manual
Standard Timing Control
CAS Latency Time.........................: 5
tRCD ....................................: 5
tRP......................................: 5
tRAS.....................................: 18
Advanced Timing Control [Press Enter]
tRRD.....................................: 4
tWTR.....................................: 4
tWR......................................: 6
tRFC.....................................: 62
tRTP.....................................: 4
Command Rate (CMD) ......................: 2T
Channel A
Channel A Timings Settings
Static tRead Value......................: 9
Channel B
Channel B Timings Settings
Motherboard Voltage Control
Load-Line Calibration.....................: Enabled
CPU Vcore...............1.22500V..........: 1.343v
CPU Termination.........1.200V............: 1.300V
CPU PLL.................1.500V............: 1.450v
CPU Reference...........0.760V............: 0.830
MCH/ICH
MCH Core................1.100V............: 1.300v
MCH Reference...........0.760V............: 0.800v
MCH/DRAM Reference......0.900V............: 0.900v
ICH I/O.................1.500V............: 1.450v
ICH Core................1.100V............: 1.300v
DRAM
DRAM Voltage............1.800V............: 2.1v
DRAM Termination........0.900V............: 0.770V
Channel A Address Vref..0.900V............:Auto
Channel B Address Vref..0.900V............:Auto
Advanced Settings
Limit CPUID Max. to 3.....................: Disabled
No-Execute Memory Protect.................: Enabled
CPU Enhanced Halt (C1E)...................: Disabled
C2/C2E State Support......................: Disabled
x C4/C4E State Support....................: Disabled
CPU Thermal Monitor 2(TM2) ...............: Enabled
CPU EIST Function.........................: Disabled
Virtualization Technology.................: Disabled
__________________
http://img690.imageshack.us/img690/9...4131ghz.th.jpg
