Just fixed a hung switch and a couple of minor issues so output should be back up.
DDTUNG:cool:
DDTUNG:cool:
Got all of mine back on WCG now...
The XS Xpress is gathering steam..:up:
And i just replaced a single core with a dual core, will be replacing another single core tonight.
actually it's more like adding a dual core this time round,lol..........
the one I replaced last night was an old hp celeron 2.4 ghz single core it got replaced with a amd 3800 X2. The X2 it is much faster just on one core...........took me a bit to get both cores operating had to go into the os and load the multi cpu driver for 2000 pro. I should see a good improvement in points.
The one going online tonight is an opteron 165 dual core. should be as good if not better.
XtremeSystems 5,377,955
:up: headed back up!
Q9550 on the way for quad #50.:)
DDTUNG:cool:
My Q9450 is cruching along at 3.76, finally stopped tweaking it so I can just let it run now.
Edit: And I'll get a phenom system crunching soon, I have 2x1gb sticks and an Opty 1356 coming in on Wednesday or so. Just gotta hope its as good as the 165's were for that generation.
Its on a TRUE, 50C load when the room gets hot during the day and 47C at night. It has 1.325v set, but its at 1.24 while crunching. Its been going for 4 days now, I think its good.
Yeah, just wish the X48 boards were better clockers. I would be able to do 4ghz if there wasn't a problem with me using a higher fsb. But, having a phenom system crunching would net alot more points than an extra 250mhz.
I have the X48 board because I was planning on doing a crossfire comparison, but my phenom board/cpu was giving me problems so its on hold atm. I'm buying a SB750 board when they're out so that should make everything better.
