does anyone know how low should set fine delay to? is lower better? and should i have it on "more aggresive" while its unstable or would it be better to have it on auto till its stable?
is there any official review on UT X48-T2R ?
Clock fine delay isn't a performance setting like subtimings. The lower clock fine delay values don't mean loose settings at all - they're just values which need to be tuned to match your memory/mem divider/mem timings optimally. OCCT and prime95 test different things only way for true stability is test every app you use.. you can only say a cpu is OCCT or prime95 stable if you only use one app heh.
Lowering fsb to reduce mem speed is fine in finding clock fine delay values.
what the max FSB Touched ??????????
this motherboard can do more than 600 with liquid on chipset ?
Just did this one, getting there :)
500x9.5 1.53v 4750Mhz 1:1 5-5-5-15 1000Mhz RAM 333/667 Strap.
http://valid.x86-secret.com/cache/banner/349436.png
Click Image For Full Size.
http://www.pics-clunk.org.uk/dfiltx4...r-wprimesm.png
More here.
very nice info clunk, read that whole thread :up:
I also saw your review of the board with the geil black dragons (2gbx2). Anything past 3.6Ghz lands me either into code 1 with OCCT or corruption/firefox crashes. Would that be the RAM timings? I have gotten it to boot into windows up to 4.1 though. Any suggestions for 3.9+ stable?
Q6660
dfi x48
G.Skill pc8000
edit: I am occt stable for 30+ but not occt and prime for longer than 4 minutes ;(
Code:CPU Feature Page
Thermal Management Control................Disabled
PPM (EIST) Mode...........................Disabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Disabled
Execute Disable Bit.......................Disabled
Virtualization Technology.................Disabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 1
Shutdown After AC Loss....................Enabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................9x
CPU Clock.................................416 MHz
Boot Up Clock.............................Auto
DRAM Speed................................333/800
PCIE Clock................................105 MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................1.475V
CPU VID Special Add.......................100.23
DRAM Voltage Control......................2.1V
SB Core/CPU PLL Voltage...................1.10V
NB Core Voltage...........................1.555V
CPU VTT Voltage...........................1.453V
VCore Droop Control.......................disabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL1/3 REF Volt.......................133
CPU GTL 0/2 REF Volt......................122
North Bridge GTL REF Volt ................102
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Enabled
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................3
Precharge Delay (tRAS)....................15
All Precharge to Act......................4
REF to ACT Delay (tRFC)...................48
Performance Level.........................8
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................2
Write to PRE Delay (tWR)..................14
Rank Write to Read (tWTR).................11
ACT to ACT Delay (tRRD)...................3
Read to Write Delay (tRDWR)...............8
Ranks Write to Write (tWRWR)..............4
Ranks Read to Read (tRDRD)................5
Ranks Write to Read (tWRRD)...............4
Read CAS# Precharge (tRTP)................3
ALL PRE to Refresh........................4
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Enabled
Channel 1 Phase 1 Pull-In.................Enabled
Channel 1 Phase 2 Pull-In.................Enabled
Channel 1 Phase 3 Pull-In.................Enabled
Channel 1 Phase 4 Pull-In.................Enabled
Channel 2 Phase 0 Pull-In.................Enabled
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Enabled
Channel 2 Phase 3 Pull-In.................Enabled
Channel 2 Phase 4 Pull-In.................Enabled
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................More Aggressive
DIMM 1 Clock fine delay...................Current 89ps
DIMM 2 Clock fine delay...................Current 456ps
DIMM 1 Control fine delay.................Current 534ps
DIMM 2 Control fine delay.................Current 289ps
Ch 1 Command fine delay...................Current 801ps
Ch2 Clock Crossing Setting................More Aggressive
DIMM 3 Clock fine delay...................Current 89ps
DIMM 4 Clock fine delay...................Current 400ps
DIMM 3 Control fine delay.................Current 367ps
DIMM 4 Control fine delay.................Current 356ps
Ch 2 Command fine delay...................Current 801ps
Ch1Ch2 CommonClock Setting................More Aggressive
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
Hello all,
I am considering buying this board as it seems to be the best clocker and I am using water.
I am not sure however which brand of memory is best for DFI, since I never bought DFI in the past and have been using asus always.
For some reason, I like corsair ram and quality and been think to get 2 kits of 2x2GB 8500C5 dominator for a total of 8GB RAM.
Do you think with 4 sticks will be harder to overclock? Do you agree that corsair will work nice with DFI (and this board) or should I get something else prooven to work better (no experience here).
Finally, I have -NO- clue how to tune/setup this board and I keep reading about GTL and LOTS of settings you guys change and tune and being an asus newb myself (and AMD!) I feel lost.
In summarry,
Is this the "best" overclocking board for now?
Is corsair a perfect match for this board?
Is a Q6600 or Q9xxx or X3xxx series cpu fully compatible and will overclock best with this board?
Thanks for your input as I trust the experience of members here to decide on my parts :)
thanks, ive lost my stable overclock now anyway. having 4 sticks its damn hard to get stable past 450/1080 ive tried everything i can. i read that edge of stability , but couldnt understand any of it. it really needs to be translated into english lol.
my pc had a nervous breakdown and has reset its bios. i even lost my raid0 for a while but i have it back now. i guess its back to the drawing board.
if it doesnt work ill have to get rid of those cheap and nasty crucials.
are there any guides around for clock fine delay? like a "clock fine delay for dummies" guide? i really cant get my head around how it works. gtl isnt a problem becuase i just follow clunks chart but clock fine delay is a bit of a mystery for me. i did google it but this thread is the only thing that comes up.
so has it been established that the dfi x48 can clock better than the x38 mobo?? im thinking about buying this one.. but i own the x38 now... any advantage at all?? thanks
great info guys thanks for sharing.
I'm now running 8GB and 9x420 and I think I'm also "getting there". Previously I would get random BSODs, but after tweaking all I got was one core failing in prime (FATAL ERROR: Final result was xxxxxxx, expected: xxxxxxxxx), the other 3 are still running after 13 hours. I upped the NB voltage to 1.555 from BIOS, set the latencies a bit more loose, and upped the cpu voltage a bit. I'll try tweaking the NB GTL value now if it has any impact.
Did a 5130Mhz one here.
http://valid.x86-secret.com/cache/banner/349549.png
Nice way to end the review :D
Hello everyone!
I just got this board today but im having the same boot problems that i had with my Asus Rampage. Board beeps when i put memory at slots 1-2 (1-2, single 1, single 2, 1-3 or 1-4 etc... all fails to boot C1 error) but if i put the memory at slots 3-4 or just single 3 or 4 computer boots and works great.
Both board i tried this memory were x48 and i tried on other board and memory works great, so i guess its this a x48 non-compatible issue?
Memory is Geil Evo One PC8500 4Gb pack (2x2Gb).
What can i try? :down:
Send the memory back and get a different brand?
Edit: There is a problem with some OCZ modules and ths DFI X48 and they provide a fix whereby you have to reflash the modules yourself, so maybe this is a similar issue, might be worth contacting Geil to see if they have a similar solution?
closest would be my info at http://i4memory.com/showthread.php?t=4743
Just think of clock fine delay like GTL tuning only difference, is there is no set table to go by like GTL. each memory module, different mem divider, mem clock speed and timings will alter the clock fine delay values. The info at http://i4memory.com/showthread.php?t=4743 just sheds some light on what to do when you hit a memory clock speed/instability ceiling.
Use http://i4memory.com/showthread.php?t=4743 with memtest86+ v2.01 to figure out initially what clock fine delay values will help lessen or eliminate memtest errors.
Weird part is, now i tried QX9650 first time on DFI LT X38, i find it helps stablise FSB too 9x445FSB 32M pi stable so far at CPU VTT 1.28v - no need for crazy CPU VTT volts >1.5-1.6v :)
I was going through some FAQs in the water cooling forum, and one of them mentioned not WCing the NB. Now maybe it's a few years old and attitudes have changed, but if I'm going to WC the CPU and I want to hit at least 450 FSB (anything higher is just gravy to me), would WCing the NB be a very good idea, not really needed because of the stock NB air cooler, or a certainly can't hurt and looks better idea?
