Originally Posted by
BobHarris
Overclocked from 200MHz FSB to 300 FSB, vcore at 1.36v in BIOS. EIST enabled, C1E enabled, TM2 enabled. Boot into windows. cpuz and speedfan shows that the voltage does not go lower when the multiplier drops to 6 from 9. The voltage always stays at 1.328 at idle and drops to 1.312 at load. Why doesn't the voltage drop a little bit when at idle and the multiplier is at 6?
At stock speed, the voltage is 1.15v at idle multiplier at 6, at load the multiplier jumps to 9 and the voltage is 1.296. There is not voltage gap between idle and load when overclocked to 300fsb.
Speedfan temp2 is 12C higher than core 0 or core 1. What is temp2? When overclocked, temp2 jumps to 70C while core0 and core1 are at 55C. the temps can't be right.
