4/20/2010 2:06:47 PM Benchmark results:
4/20/2010 2:06:47 PM Number of CPUs: 2
4/20/2010 2:06:47 PM 2270 floating point MIPS (Whetstone) per CPU
4/20/2010 2:06:47 PM 4784 integer MIPS (Dhrystone) per CPU
X5650 @3.8Ghz(173x22) 1.21v
w7 64bit
BOINC Version: 6.10.43
4/20/2010 11:44:39 PM Benchmark results:
4/20/2010 11:44:39 PM Number of CPUs: 12
4/20/2010 11:44:39 PM 3459 floating point MIPS (Whetstone) per CPU
4/20/2010 11:44:39 PM 11165 integer MIPS (Dhrystone) per CPU
http://img.techpowerup.org/100420/Capture043.jpg
I guess I could post a screenshot:
http://img256.imageshack.us/img256/5189/laptopcpuz.jpg
edit:
http://img7.imageshack.us/img7/1461/boincbenchmark.jpg
Yes, the term "screenshot or it didn't happen" has particular meaning in this thread. ;)
well my performance has gone down a little since the newest recommended version 6.10.43 and i aslo dont get anny projects annymore ...
i7 920 @ 3.8
Windows XP x32
Boinc 6.10.43 x32
Benchmark results: Number of CPUs: 8
3623 floating point MIPS (Whetstone) per CPU
8809 integer MIPS (Dhrystone) per CPU
Config :
http://i263.photobucket.com/albums/i...ulldetails.jpg
My problem is solved now i have projects again :)
http://img219.imageshack.us/img219/6033/qweq.jpg
http://img20.imageshack.us/img20/7646/klkqb.jpg [927
core i7950,Win7 64........,Bionic 6.10.43.x64
21 Apr 2010 9:46:38 PM Running CPU benchmarks
21 Apr 2010 9:46:39 PM Suspending computation - running CPU benchmarks
21 Apr 2010 9:47:10 PM Benchmark results:
21 Apr 2010 9:47:10 PM Number of CPUs: 2
21 Apr 2010 9:47:10 PM 3988 floating point MIPS (Whetstone) per CPU
21 Apr 2010 9:47:10 PM 11504 integer MIPS (Dhrystone) per CPU
21 Apr 2010 9:47:11 PM Resuming computation
http://valid.canardpc.com/show_oc.php?id=1145508
http://img191.imageshack.us/img191/5748/72621152.png
What does the folding use, Floating Point or Integer, or is it a mix of both?
I7 920 #1 Gaming/Crunching @ 4.5
http://www.straferight.com/photopost...3/Crunchin.jpg
I'll post up the new 920 in a bit, still setting it up.
My home PC numbers:
http://img46.imageshack.us/img46/5016/testsv.jpg
If anyone has a Phenon IIX4 that isn't being used, lemme know.
FYI those core temps are useless and misleading! AMD and Intel rate their CPUs by Tcase which is what the bios reads. Core temps are not the same as the CPU temp. You should use the monitor that came with your motherboard or similar that displays the single CPU temp like the BIOS does, that is the only CPU temp reading you can actually use and compare to AMD/Intel max CPU temp ratings.
oh ok, thanks.
http://i44.tinypic.com/206lled.jpg
Vista x64 SP2
BOINC Manager: 6.10.18
Boinc 6.10.45 x64
Win 7 x64
http://i168.photobucket.com/albums/u...7/wcg_test.jpg
http://i168.photobucket.com/albums/u..._2007/CPUZ.jpg
Just ran bench on my new Air Cooled i7-860 running at 3800 Mhz (100Mhz slower) (no SC software on that machine yet).
and got 3508/12610. Damn it's putting out more when running at 1.25v on a Gigabyte P55A-UD3 mobo on air with the same temps as the i7-920 WC rig. (62c loaded)
John
I wanna get in. Here's my main rig. It will have my 1090T in it soon.
I expect the same numbers or better assuming 4ghz or higher is good for 24/7 use.
Win7x64, 64bit Boinc
very nice reckoinu, just need to add the model of the cpu like core i7 920 for example and that graph would be perfect.
Snip: Bionic 6.2.28 for W_intelx86
W7-64
Q8300 stock because its sitting on a packard bell mobo, Win 7, v.6.10.43
2542 fp
7009 int
Too much hassle haha, the only way to do it is if everyone would post their specs and results in the same text format so they are easy to copy to a spreadsheet or program that can read it, entering data by hand is a pain! EDIT I see a couple of other members have already tried this, the data is from like 2007.
you can add my boinc ver if u want its 6.10.43 and im running win7x64 :)
Im glad im second :P
i7 920 @ 3.6 Windows 7 x64 BOINC 6.10.43 (64bit)
CPU=8
fp/cpu 3276
int/cpu 10494
Xeon E5520 @ 2.26 Windows Server 2008 R2 BOINC 6.10.43 (64bit)
CPU=16
fp/cpu 2062
int/cpu 6539
