nope, stays onQuote:
and this is possible that it's just what BIOS it is shipped with, they will change the rev # for any little minor changeQuote:
The rev# has nothing to do with the bios...
I was running 2395 but it would decide to randomly NOT post focring me to clear cmos, swap ram, change settings, and swap back. Reflashed 2333 and problem free with 3.75ghz orthos and 3.9ghz 3d on air.
I sort of hate you.Quote:
Originally Posted by afireinside
Anyone know what the differences between the revisions are? They don't show the revisions in the product specification on intel's site.
it could be any physical change to the board, like capacitor or anything else.Quote:
Originally Posted by Teratism
just a thought, I thought I remembered some company that did that:)Quote:
Originally Posted by pcdoc1
Originally Posted by Charloz24
Yes I looked with core temp 0.94, everest ultimate 3.05, TAT all the same, IDLE about 40° full load 66-68° sometimes the idle is under 40° than about 50°. I donīt know if this the "thermal paste" ?? On Monday I will buy the arctic ceramic paste in the shop. Maybe the temps go lower!
What about the current prozessor voltage in the bios? Is 1.325volts always standing also when I go on 1.4vcore voltage?
Also on Intel orig. tools worked not probably. Intel Control Center freezes, Intel Desktop Center didnīt start with my board. "initialitation failure" "rofl"
Also in Everest he is not showing all voltage infos only CPU core when I click on sensors. In my mind I Think on the first start of everest it was all shown and after cmos clear even not! "strange"
helping were welcome^^
Ps: When the windows run in IDLE now the temp is 30-31 after stress test it goas to 68 and than when I stop the test about 3hours the IDLE temp is about 40-42!
anybody knows if C1E under the maintenance bios menu should be enabled or disabled?
With the Normal P5B does the Bios give the option for Southbridge Configuration with the latest Bios?, problems with a Modem/Fax not showing up and a Netgear wireless adapter playing up on win 64 due to win 64 Drivers but maybe the Southbridge controller not showing up?
Should the option for Sothbridge be in the latest Bios, if so what can cause the SB from not being recognized?
Currently at :
http://img204.imageshack.us/img204/8...tledot5.th.jpg
Settle around the 3300 range after AS5 has set in failing Prime at 2 hours at the moment due to Temperatures or the Timeings for the Ram.
All Value components
damn sweetQuote:
DisabledQuote:
Originally Posted by alexankius
Ignore it. That's what it always says.Quote:
Originally Posted by pushook
The Intel Desktop Control Center has problems if you run any other monitor programs (like cpuz) first.Quote:
Get the latest beta version from the Everest web site. It has full support for the XBX2. Beware though, a lot of us have problems with Everest and Sandra causing the board to lock up.Quote:
Bios update to rev 2333 pre.change 504 post change 505.Quote:
thx for the help. I have now the newest everest 3.05. Same thing no correct infos on CPU and no infos for the voltages on the sensors!
I have CPU Z not running, Intel Desktop Program didnīt start!
also the program speedfan is not working on my machine!! There is no data!
why this?
Is there any program to set the fans seperatly?:confused:
to check the changes on Revisions for the D975XBX2 you can sign up for Intel Product change Notifications at Intel.pcnalert.com.Quote:
the only changes from #503 to #505 have been Bios updates.
Well does my board blow or what? I can't get over 440 fsb stable on 1066 strap :( 1.7vmch 1.425vfsb. Would more vfsb help or is it mch mod time? Didn't have time to test. I managed to run a 4ghz 8m on 1333 strap but it's pretty slow compared to 1066.
My 24/7 OC until my water comes. 1.5V bios. This chip rocks :D
http://sean.nickfire.com/core2redux/3750orthos230.JPG
And a 32m @ 3600
http://sean.nickfire.com/core2redux/3600-3334-32m.JPG
25 seconds better than my 4-4-4 run on 965 and I'm a little less tweaked and max mem won't work. Stupid matrix raid, I have my main os on raid 0 and then my bench os on raid 1 and the boot loader didn't install. Now to pick my OS I need to put raid 0 or 1 first in HDD boot order. Bit of a pain but oh well. When I set max mem it won't apply though and it's pissing me off, losing valuable 32m time!
After flashing back to 2333 BIOS this Intel setup has been a much more pleasant experience than my 6600/p5b combo. Great board!
Did you get the latest beta version from the everest forums? It should show the info.Quote:
Try uninstalling Intel Desktop Utilities, and Intel Desktop Control Center, then re-install the IDCC.
Speedfan doesn't work with the aSC7621 monitor chip on these boards. I've tried to contact Alfredo about this several times but he's not answering. I'll keep trying.
thx I will look in the forum yet.^^
The temp prob is always there. I will look tomorrow for a better thermal grease.
For 340FSB the IDLE is now at 40-42° and under full load it raise to 68!!
I think for this Thermltake Tower I have with 5fan and a HSF from scythe samurai it is to high!
vcore default:for 340FSB is 1.188 - ram is on 667@425MHZ 4-4-4-2:)
Originally Posted by gtj
This is a great table. I know this is asking a lot but could you or anyone else make a table like this for other CPU freq. besides 3.7. Maybe like 3.4, 3.5, and3.6? Is there a mathmatical way to do it so you dont have to try every one and write down the numbers?
Originally Posted by mojaveron
yay, i was right!
nope your board doesn't blow, you are getting very high on the 1066 strap and you should be proud :p:Quote:
CPU freq is always FSB*CPU multi, doesn't matter what ref freq you are on.Quote:
Originally Posted by chaotic646
edit: and i just realized what you are asking, hehe, do you have a calculator? or excel? just take the [(FSB)/(ref freq)]*(mem freq) = memory speed in DDR2
I understand that but I was talking about the other information on the table like the memory ratios for each strap and memory speeds. I want to know which Mem. freq and Ref. freq. will give me 1/1 ratios on different cpu frequencies like 3.4,3.5,3.6 since it changes as you move your FSB up or down.Quote:
Originally Posted by Blauhung
ah now i get your question. FSB doesn't matter at all, divider is only set from the reference and memory frequency. If you leave the ref/mem freq alone the divider will always be the same at any FSBQuote:
http://www.oliviercouture.com/PC/Ben...1M_4010mhz.JPG
Highest OC so far. Its a B chip so it runs pretty hot. It is not Stable but enough for SuperPI. I would like to 3D bench at that speed, maybe raising vfsb ? I am currently pushing the limmits of that 1066strap. Tried to boot at 460mhz x9 for beauty shot with 1066 and OS corrupted.
Right now im at 3800 24/7 stable, im am currently running 3850mhz and will try orthos stable, 1.465v is pretty much the max i can have for Orthos, Loads at 69coretemp and 73c IDU.
http://www.oliviercouture.com/PC/Ben...table_3800.JPG
AFI: Wow 82c load in coretemp, you make me look like a :banana::banana::banana::banana::banana: to be afraid to go over 1.465v because of my 69c load. Is there a reason why you are confortable with 82c load ?
