Thanks mysticmerlin....btw that was only from mid afternoon till night....i will check and post back when system levelled out.:up:
so many new crunchers... :D:D:DQuote:
moab11 passes 10,000
nyc32 passes 7,500
zoob passes 1,000
ocZZZ passes 500
Ajarn passes 100
Ajarn passes 50
jtkeenstyle passes 50
Metroid passes 50
eden40000 passes 50
crassvs passes 50
123sarah passes 1,000
A-X-E passes 100
A-X-E passes 50
eden40000 passes 100
crassvs passes 100
cardinaldebiere passes 100
cardinaldebiere passes 50
wizardz passes 100
wizardz passes 50
Cole.ogg passes 100
Cole.ogg passes 50
Metroid passes 100
hefonthefjords passes 50
kakbit passes 50
Dunii passes 50
St3vil_68 passes 50
WayneBike passes 50
Kallenator passes 50
corruptor passes 50
Tendou passes 50
winterheart passes 50
levish passes 50
Gehacktesmacher passes 50
terramir passes 50,000
A-X-E passes 200
crassvs passes 200
Toysoldier passes 200
Toysoldier passes 100
Toysoldier passes 50
hefonthefjords passes 200
hefonthefjords passes 100
levish passes 200
levish passes 100
Cole.ogg passes 200
St3vil_68 passes 100
Kallenator passes 100
winterheart passes 100
jgigz passes 100
jgigz passes 50
V1King passes 100
V1King passes 50
WayneBike passes 100
Dunii passes 100
jtkeenstyle passes 100
Reaktori passes 100
Reaktori passes 50
corruptor passes 100
ShaggyXS passes 100
ShaggyXS passes 50
VOCCH passes 100
VOCCH passes 50
Twisted47XtremeSystems passes 50
Finchnz passes 50
dave_graham passes 50
jbdiablo passes 50
R2medeu passes 50
more troops .. great job guys :up:
Avg. Run Time Per Result (y:d:h:m:s) 0:000:01:57:04 Sweet..
You should be able to pull off ~580 WCG points per hour with that setup. :up: WCG lists points/hour of runtime which is per core, so multiply by 4 to see your rigs total production per hour. It will take a few days for the validation process to catch up with your production though.
Just noticed I made it to 500k during my holiday. Finally :D
don't get jealous get NewEgg :ROTF:
Well, well...
I have loonngg and intresting storry about work and hardware shop :D
Oh I love stories! Especially the ones about geek pr0n and pics like a playboy that is all silicone not just the uuummmm.........you know. :hehe:
<<<<<<< Save the uuummmmm's :up:
no Error and Invalids are not normal and are bad. What is your system pieces that the error's are on and what clocks?
Edit: NM I see the sig now. It is that system right? Are you positive it is 100% rock stable? WCG will not be happy some times even when the "bench mark programs" are. If it keeps up drop the clock back 200mhz and see if that helps.
Hi...not sure if you want full log and clocks do you mean my cpu in sig?....both look similar...here's the end bit.
<core_client_version>5.8.15</core_client_version>
<![CDATA[
<stderr_txt>
World Community Grid AutoDock (projects/www.worldcommunitygrid.org/wcg_faah_autodock_5.41_windows_intelx86) version Failed to get VersionInfo size: 1812
INFO: No state to restore. Start from the beginning.
ERROR: Restoring checkpoint failed. Unable to restore state!
INFO:[08:29:53] Start AutoGrid...
autogrid: autogrid4: Successful Completion.
INFO:[08:30:50] End AutoGrid...
that looks like it random reboot that BOINC hadn't written to the hard disk and was unable to restart or recover from.
Hi mysticmerlin...i think i know the problem...when i primed it and passed i knocked the vcore back a notch...and although it has'nt shown to be unstable it obviously was...so i just put it back!...just hope i ain't got any more like that.:( ....thanks for clearing that up i will keep an eye on it.
I had the same problem with my first run @3.7, backed off a bit and all seems to going OK... I can't wait for these hot days to end or to get a better A/C unit. :D
I don't think Vista 64 and BOINC are playing nicely. Every time I shut down all my WUs are marked error or invalid. I know they're not done because I shut down before they're complete. Next time I boot up, it grabs NEW WUs... grrr.
Hi guys...just checked and altogether over the past 3days so far i have 18 valid... 12 pending...errors 2 and 1 invalid the newer error don't even seem it started correctly....my clock was prime stable and my temps running WCG dont break 50c...what do you think?.
Here's full log of last error.
<![CDATA[
<message>
- exit code -1 (0xffffffff)
</message>
<stderr_txt>
INFO:[11:40:18] Start AutoGrid...
INFO:[11:41:15] End AutoGrid...
Beginning AutoDock...
autodock4: wrong number of values read in. Check grid map!
__________________________________________________ _____________
2 errors in 3 days indicates something is wrong ...
Are you sure your system's stable? How long did you run prime (small or large fft?)
Hi Jaco...i gave it 6hrs+ small FFT's
