Those are the ones :)Quote:
so far i am stable at 366 fsb @ 1.4v 1.55mch.
i cant get the Gskill HZ ram to run at cl4 with memset no matter what it just locks up even at ddr2 700 speeds yet on a p5wd2-e it would run at ddr2 1000 with 4-4-3-2 @ 2.3v.
the ram is running at ddr2 916 here.
Anyone know when the RD600 motherboards are out? Wondering if it's worth waiting a short time for, links to sources would be appreciated :)
DS3, chipset is hitting 61 when I don't have a fan on it. It's in the TJ07 case and with the sides off. Gonna try tomorrow with the sides on and see if that makes any difference. Will try reseating it too but I think it's starved of airflow.Quote:
Originally Posted by fornowagain
Strange that, I'd put up the MCH voltage. Stuck these on to see the results at 3.6GHz 4-4-4-12. What the memory voltage?Quote:
Originally Posted by leejsmith
http://img57.imageshack.us/img57/741...est2ag0.th.jpg
http://img57.imageshack.us/img57/779/everestuz3.th.jpg
Just for a laugh. If I dare go over 1.55v this is ok for a few benches. But I doubt it's prime so don't ask.
http://img57.imageshack.us/img57/8179/37xo0.jpg
Is this for real??
Retail E6600 @ 3.7 @ 1.213 volts?? :confused:
What you mean 'Just for a laugh'?
Course it real, cheek:slapass: Don't take to much notice of cpu-z voltages, its buggy, should say 1.55v. You never tried something just for a laugh, to see if you can?
Ooh... £1 worth nearly $2. Makes a little holiday and shopping trip over the pond quite interesting....
I have the mch @ 1.55 and vdimm of 2.2 upto 2.3.Quote:
there must be some other setting i need to change so gooing to look through coolers threads and check out the 1066 boot strap stuff.
1.55v is nothing to be scared of..
Max out the MCH, just get a fan over it, turned mine on first boot at 1.65v. And why so much Vdimm? Its not needed at those speeds, it'll make em hot.Quote:
trying to run them at the same speed as on my p5wd2-eQuote:
ddr2 1000 4-4-3-2 2.2V
The memory timings/speed are not going to do much for the overall system speed. I'd of thought the first thing is to get the FSB up, then worry about the memory bus. I'd stick to the 1:1 ratio as well, I'm not sure the other ratios are working that well tbh.Quote:
the ram at 4:5 is working ok but i get the same problems with ram at 1:1.Quote:
the only thing i have not checked is the version of memset i am using.
Well impressed with my £90 2GB ADATA Value :D
Stock DDR2-667 5-5-5-15
Memtest 30 mins DDR2-833 5-5-5-15 2.1v
http://img487.imageshack.us/img487/7194/memtestlm6.png
with what FSB?
416 @ 4:5 = 333 I would think.Quote:
Originally Posted by don_vercetti
Great value ram btw.
Gold Star for you :)Quote:
http://img461.imageshack.us/img461/2...memtestqc3.png
:D and going up
What are you planning to lap with this eBay lapping stuff then? The CPU itself or the Asus heatsinks?
The cpu
Why thank you.:cheer:Quote:
How hot did they get? I was running S&M memtest on my HZ at 410 2.2v and they got bloody hot, to hot to touch. Had to mount a 50mm fan above em. Suprised me, way hotter than the DDR HZ on my last rig.
hehe, not very hot actually, I can keep my hands on them fine. 833 is fine on 2v maybe 1.9v but can't be bothered to run more memtest right now lol.Quote:
DDR2-900 crashed after 5 mins with 2.2v, they should do it with 2.3v but for 24/7 I wouldn't run that so no point memtesting it...
Made some progress last night.
i am stable at 380fsb 1.45V vcore 1.6V mch 2.2Vdimm ram @1:1
Memset was causing the problems running cl4 but i was ok setting it in the bios.
did a 3d2k1 run and was only a few points shy of 50K.
Sorry for being surprised when you just post an image and 'Just for a laugh'. What was i suppose to think?Quote:
To be fair...i'm still surpised as yours is the first retail E6600 that i've seen anywhere near 3.7 and well above the supposed fsb wall at 360+...even if it does take 1.55v to get there.
Care to provide a bit more information? bios version? other voltages? etc.
This is encouraging for retail cpus as so far they've failed to live up to the ES's.
