dark-redeemer add some dye :] It looks good, but can look better :)
Dark-Redeemer: those are sexy ass AnFi blocks.
dark-redeemer you did such a awesome job running all the tubing and it looks so symetrical. very very nice work!
Thank you :)
Yes, it is a laser cut.
Wow! Is that the P5W DH Deluxe rig? If so, are you using the EK NB4 Intel water block to cool the northbridge? Also, how easy is removing that graphics card with that southbridge tube there?
Nice tubing runs redeemer, that front panel is the sex.
BTW what cpu block is that?
nice pics dark
Boo...I was hoping for somebody to post pics of a full P5W DH Deluxe water cooler rig.
dark-redeemer, what cpu block is that?
Very nice rig there Dark Redeemer...the A-F blocks are looking good.
Very nice rig, but what pump and radiator are you using? I'd hate to think of your flow rates with SB, CPU, NB, VGA, 2x MOSFET and RAM all in the one loop, and the heat-dump must be extraordinary.
I believe it's an EK-Wave with an Acetal top. The precursor to the Supreme, it had a much less restrictive design than the Supreme (about on par with the FuZion) but offers worse temps than an Apogee GT or FuZion.
Hey dark, all that on one rad and pump? that's pretty daring.
@ dark-redeemer,
I did not see any mention, but what RAM block is that?
AnFi ram block. custom made German block.
Nice work Dark-redeemer.
Just a question though does your res "splash" much seeing as the input is above the water line?
it's just a mips freezer with a custom anfi top ;)
Wow, thank you guys. That's a lot of response :)
The cpu cooler is an EK Wave with acetal top as mentioned before. I bought it almost a year ago and i don't see any need to change it. Of course it doesn't chill as good as e.g. an EK Supreme. But it looks much better than any other cpu cooler in trade.
The ram cooler is a Mips Freezer 4 with custom made acetal top by Anfitec. Mainboard is an Asus Striker Extreme. I do have a P5W, too. But without watercooling.
Changing the graphics card without disconnecting the NB tube is rather difficult I guess. Never tried this before.
Everthing is cooled by one Laing DDC and a single Thermochill PA120.3 radiator. The temps are not the best but they are adequate. Even with the highly overclocked CPU.
There's only few splashing in the reservoir when you put enough water in it.
