Nice work Adya, built not bought :up:
I've never been a fan of yellow coolant/tubing, primarily because of what it looks like you're running as coolant :D
I think it looks f*cking awesome
http://i265.photobucket.com/albums/i...0/P1040762.jpg
sig'd rig...awaiting its new RAM.
I see what your talking about. Its really not that bad. If it was I think I would have had a difficult time getting the sli bridge on but it went on easy, and I haven't had any problems so far. I think its just the weight of the block, the thing is very heavy even without anything going through it.
empty-Q: indeed - more pictures please :)
Will do, just fooling around with my camera, the above pic was by far the best. These are my latest pics, please ignore the grain, I was fiddling with the camera. Slowly getting better ^.^
http://i83.photobucket.com/albums/j2...r/DSCN0372.jpg
http://i83.photobucket.com/albums/j2...r/DSCN0374.jpg
http://i83.photobucket.com/albums/j2...r/DSCN0371.jpg
http://i83.photobucket.com/albums/j2...r/DSCN0368.jpg
http://i83.photobucket.com/albums/j2...r/DSCN0370.jpg
http://i83.photobucket.com/albums/j2...r/DSCN0363.jpg
@Empty_Quarter: how come there are no more rear fans?
2 less fans to worry about. 92mm fans arn't the quietest unless I get a noctua. I dont really need the rear fans.
Decided to go caseless. It's all a bit messy, yes.
http://img230.imageshack.us/img230/6183/imgp1618zc4.jpg
Had a problem with the tubing (1/16 wall) collapsing with the D5 Vario so had to line it with zip ties. Even with them, I can still only run my D5 at setting 3. However, when holding the tubing to make sure it didn't collapse at setting 5, I saw now temp differences in idle or load.
I'm stumped. Must be that the flowrate isn't the limiting factor for my temps currently.
Hey Cedric!
Is this thing still portable? :D ;)
Greetings to Hong Kong!!!
If by portable you mean a complete inability to even shift it one inch, then yes, it is absolutely portable :D
Well nothing is actually nailed or bolted down so I can slide it across the table. That's some measure of portability.
I'm actually waiting on shroud dimensions for my 160 before I cut into my PC7 so this is merely a temporary solution.
Unfortunately, adding an extra 2 GB to my rig killed my ram OC and am no longer able to run 8x450 :(
And greetings to the land where you live and/or originate from.
no picture?
Guys...
All of you out there drooling at the 9800X2...
Asetek, makers of the VapoChill has now announced the availability of its latest creation - a liquid cooling system for the hot, heavy, long and why not powerful, GeForce 9800 GX2!!!
http://www.tcmagazine.com/images/new...GX2_LCS_01.jpg
http://www.tcmagazine.com/images/new...GX2_LCS_02.jpg
Pictures courtesy of TCmagazine.
Offtopic
@CedricFP - How are computer parts/accessories pricing in HK? I'll be there for 2 weeks for business and was just wondering if I should keep my eyes out for some good deals?
sorry for offtopic
How does that Asetek cooler work? Does it use the fan just for the RAMsinks etc?
Hi guys! I just got the 8800gts g92 and put it under :) Mobo is EVGA 680i SLI (second - RMA) and this one's PCIe 1 and blue slots aren't working. I'm forced to run the gts in the lower one :((
EVGA 8800gts 800/2100/1150 no VMODS. Swiftecg MCW60
Q6600 3,6 ghz 1,35Vcore Swiftech Apogee GT bowed
Eheim 600 Compact Inline converted pump and 240 Audi Heatercore with 2 Delta's pulling.
Temps Q6600- 35/50
GTS -38/45
the lower one is also 16x so it is the same performance so no :( faces :D
