I think it's clear tubing with black coolant. Look in the reservoir; you'll see that the coolant in it is black.
EDIT: Argh, NoobCake beat me to it.
It isn't black tubing. When you look at his reservoir, the coolant inside is black.
Also, I think he's using a MCP350/355 with one of those XSPC reservoir tops.
Oh crap, didn't notice that lol. Well I know they (tygon) makes black tubing as well....
It's black feser one coolant with tygon tubing. There are two mcp355 pumps in the loop, both have the xspc res tops. I actually had the bitspower compression fittings for the thick walled 1/2 tubing to use, but they don't fit past the graphics card on the back of the gpu water block so I decided to use the high flow fittings I had. Before I refill the loop I will try and get some extensions so I can use those fittings.
it is AFAIK. DDTUNG will ban you without an OC on your system. it is XTREME SYSTEMS after all.
HAHA!
You guys are going to force me to overclock my 9650 to 4Ghz. :yepp:
nemore pics snoony?
hey spoony i wondered with what kinda prodcut u painted your case?
I really didn't take many pictures, but I will try and take some more and get them up.
I just used spray paint to paint the case. The paint and primer were rust-oleum and the clear coat was some other brand I got at lowes.
Primer:
http://www.rustoleum.com/CBGProduct.asp?pid=146
Flat Black:
http://www.rustoleum.com/CBGProduct.asp?pid=95
Spoony,
Great job on the system. What barbs did you get for the xspc top?
I originally had bitspower compression fittings, but changed them to bitspower high flow fittings. The change wasn't because of any issues with xspc top though, so if you prefer those fittings they will work fine.
How does the paint hold?
Is it scratch resistant?
I've done mine as well but the paint is prone to flake off if handled too careless.
I think the primer is to blame, acid etchprimer would have been better i reckon but that doesn't come in spraycans as it is 2 components.
Nice job on your case btw. ;)
I noticed before I put the clear coat on it scratched very easy, but afterwards the paint held up way better.
clear coat will solve most any flaking issues, as will a good self etching primer or a well prepped case with a normal prime.
And I thought there were new pictures added. Silly me.
This thread is continuously ruined with idle non-relevant chatter. Its a GALLERY not a chat room.
http://i49.photobucket.com/albums/f2...1/DSCF2910.jpg
http://i49.photobucket.com/albums/f2...1/DSCF2912.jpg
http://i49.photobucket.com/albums/f2...1/DSCF2900.jpg
http://i49.photobucket.com/albums/f2...1/DSCF2898.jpg
SOOOOO quiet. Now all I have to is replace my 3 year old 160Gb with a 320Gb single platter for ultimate quiet! Specs are:
e2200 SLA8Z @ 3.4Ghz for now
2Gb 1066Mhz Dominator
DFI DK P35-T2RS
X1800 XT
Abit Airpace
Corsair 520W
Vista bussiness 32-bit
XSPC bay res/pump
XSPC 1/2" tube
Feser 1 UV Blue invisible + Aqua watery stuff
EK Supreme Plexi
EK FCX18/19
Noiseblocker XL2's @ 7v, Antec Spotcool without LED's
SPOONY: Please check your PM, because your system is outstanding!
I myself say goodbye to watercooling for 2 months:
http://www.abload.de/img/343-lastx9y.jpg
Why? That rig looks great!Quote:
It aint that hard... Clean the loop once every few months... no big deal.
EDIT:
It's hard to get a Q6600 to 4ghz on air anyways.
