rufus7
looks like you have the worst sample ever +(
rufus7
Yes its a very bad bad Sample. Soon i will try it with watercooling than we will see how bad is that little piece of Silicon under Prime and Stockcore. :D
http://img205.imageshack.us/img205/7...ieur8te.th.jpg
Another little Test at 1,312Vc an 2950Mhz 21min Prime Custom FFTs in place 15 minutes.
http://img263.imageshack.us/img263/2...st25m3j.th.jpg
I do also 32M @ 2.9ghz @ 1.73v
interesting'''looks like those week 36 CPUs are liking voltageQuote:
Originally Posted by Pt1t
it's bloody cold in Belgium as well isn't it heheheh cause there sure is a hell of a lot of votls
Pt1t do you have an older TBird 1400+? :)
Not so cold in belgium today , but this cpu is strange , temp isnt so high for 1.84v , got 10° on the venice with 1.7vQuote:
Originally Posted by dinos22
so what are your load temps and have you tried higher vcore :eek: :eek:Quote:
http://users.skynet.be/pt1t/144/CPUMARK_393.PNGQuote:
I m going to try Higher :slobber:
you are one crazy mofo :toast: :banana: :banana:Quote:
26c idle with 1.84v with water, 32M SuperPi stable at 2.9ghz? Thats just crazy! Keep the madness coming! Maybe the Belgian batch is unlike anything we've seen thus far. :confused:Quote:
Anyone else who ordered a Vandi special not get their delivery yet? I'm about ready to go postal on the USPS....(I'm in Baton Rouge btw...)
It`s the right Burn In for the CPU. ;)Quote:
Originally Posted by gundamit
Maybe. You can see in post 703 this 148 needed 1.424v to get 32M stable at 3ghz. Now after running over 10+ hours of Prime at both 2.8ghz and 2.9ghz I can do the same thing at 1.392v.
http://img262.imageshack.us/img262/2...vlowerv6lg.png
Fair play, You've got balls man!!!! :eek:
Ram /166 , preamble 5ns.
but my water is hot
This CPU like Voltage, but isnt hot ! Highest temp during a SPI 32M @ 1.80v is only 42° (23° in my room).
"This might be the hardest thing I've read lately to believe. I'm not saying I don't believe in miracles, because I do, but to be at 1.8v with a 144 and only be at 42c on wc(or is that 42f?) is truly a miracle. Let's see a sg ss. Make me a believer."
I am now a believer. No cpu has ever been like this before. The problem is that the cpu will not last long pouring that much juice thru it even if the temps aren't high. I sure wish you good fortune with it.
dude your chip is also something people have never seen before at ridiculously low volts and ridiculously high temps..............this just looks like it's on the opposite side.........none of you can put 1.65V on your Opterons without blowing up your room......doesn't mean this one is the same.....it could be a voltage loving Opteron.....i guess once we see a bunch of other results it will show some consistency but 2x0536 CPUs so far that love voltage you've got to start thinking maybe there is something there rather than pointing fingers :slapass:
Originally Posted by dogsx2
hey guys i get my 146 tomarrow but was interested in know if these have problems at 1:1 ? i was reading over at another forum where guys said we over at xtremesystems were getting crazy ocs but we were using dividers and not running 1:1?? ive read this whole thread and i dont realy recall any of you guys saying the mem controler on these puppys hated 1:1... anyone confirm this? i thought these had the awsome mem controlers?
thx perc,
No issues with mine, when I did my initial 1:1 testing I achieved the same ram clocks I was reaching with my old FX-55 0.13. The thing is I only use winbond based RAM so I have to run with dividers to reach the higher CPU speeds. I believe all of MM's tests were at 1:1 too, and he got above 300Mhz with his ballistix... I don't think you have anything to worry about.
Another mad belgian chip
http://img12.imageshack.us/img12/449...ronkoos0bw.jpg
(temp was 5c lower with 1.8 bios on neo2,
this is the bios which get's me lots of volts) :p:
in my case i have mushkin redline and this chips do 270 max stableQuote:
Originally Posted by Perc
in my case i cant find ram to do 1:1 there are no ram to anchieve 340 or more fully stable
look this vcore
KIDS, DONT TRY THIS AT HOME!!! :slapass:
http://img187.imageshack.us/img187/4...nosde1v5yy.jpg
Hehe , same on venice but Stable :Quote:
Originally Posted by NISCO PT
http://users.skynet.be/pt1t/0517/octt_2000mhz_vcore.PNG
An Venice3000+E3 0521DPMW same Frequency. 15Hours Prime Large.
http://img399.imageshack.us/img399/2...e15h3re.th.jpg
Did you guys that are running 1.7 and up even try with stock and then try to ease it up or did you just pop it in and start at 1.6? :slapass: I'd like to see some scaling exercises done on those. Why don't you go back to 1.4 and try again before you blow it up?
CABGE vs CABNE..Quote:
the latter are the chips that run real hot, but clock well with low voltage. :toast:
i dont understandQuote:
Originally Posted by ozzimark
are the cabge the best or the cabne ???
