I'm speechless - and hope that all good things ($$,$$$,$$$) fall in your "lab" for this Hipro :toast:Quote:
Originally Posted by hipro5Some updates for now........
This is the FINAL Version 1.2 of the DDR Maximizer Mainboard.......
http://www.thelab.gr/images/Hipro5/M..._Final_jpg.jpg
This is the FINAL Version 1.2 of the DDR Maximizer's Front Panel........
This is the FINAL Version 1.2 of the DDR Maximizer's DDR PCB........
This is the FINAL complete DDR Maximizer outside it's box - ONLY the PCB's.......
NOW...Take a good look at this photo...It is the Front panel WITH AND WITHOUT Led and Led display......We DID NOT solder the dual leds and the Led displays on the front panel.......We soldered instead of them base-pins.....We did that in case that someone of you, would like later to change the Led displays and the leds of the front panel and make them BLUE(as for the led displays) and BLUE-RED(as for the dual leds) by it's own......The only thing he has to do is to unscrew the two screws of the front panel's face,
buy the "blue-red" Maximizer's kit and place them into the bases........ ;)
http://www.thelab.gr/images/Hipro5/M...change_jpg.jpg
Here are some constraction bases of the DDR Maximizer....... :)
"The born" of the DDR Maximizer....... :D
http://www.thelab.gr/images/Hipro5/M...l/Born_jpg.jpg
Beta Prefinal front panel V.1.2
http://www.thelab.gr/images/Hipro5/M...efinal_jpg.jpg
FINAL front panel V.1.2
BETA Prefinal Mainboard V.1.2
FINAL Mainboard V.1.2
UNFORTUNATELY we encoded a MAJOR problem with the box of the DDR Maximizer......It was designed, drilled and ready for the BETA Prefinal's metrics, BUT the final DDR Maximizer's PCBs have the holes about 0.33mm in different places from the prefinal one.....500 aluminum boxes are for the garbidge now......We gave the new dimentions of the FINAL one (yesterday) and we will get the new ones in about 20 days from now(as they said)....... :(
MANY problems for the begining of our new company........I hope they end soon.......BUT we will not give up......We will continue to work hard so as to provide the best we can to you.......and this is just the start.......MANY new things are about to show up from us in the near future......Stay "tuned"......... :D :toast:
/comment
