VERY nice improvments, there. Hot damn.
-k0nsl
-k0nsl
Thanks guys.:toast:
really nice, i plan on getting one of thsoe cases sooner or later
My new chilly1 phase unit is housed in that case :woot: ... Nice lookin' comp man, awesome paint job!
Ok guys I got mine finished, well until my fan grills come in as well as my cathodes. What do you guys think?
http://www.dmp-racing.com/king/Case/
Trice Amazing...Nice case
Pics of mine :) Outside case...
http://img218.imageshack.us/img218/1...04741kz.th.jpg The WB ;)
http://img218.imageshack.us/img218/5...03974iq.th.jpg
http://img226.imageshack.us/img226/6...04310uj.th.jpg
Who needs a computer case right before? lol...
Well, I guess this IS the "Water Cooled CASE Gallery"
hehe
Originally Posted by maratus
Thank you very much.
I new to this water cooling and i am looking @ going with water. One Question for anybody here, have any of you seen or have the Thermaltake Armor case setup with internal rads in stead of external rads on the back ? this is the case i have and i was just wondering how hard it would be to make a good internal rad seup. I was looking at the Switftech Apex system or should i build a custom setup, I know the Appex has dual external rad and can i save any money by putting 1 together my self. Thanks..............:D
:D Do my house couldn't be a huge case?Quote:
Originally Posted by FragTek
My case http://www.legitreviews.com/article/241/4/ is reviewed here but I still thinking what would be the best spot too set up my rad.
In front of the removable 5.25 bays where i easily can place my rad. It can suck in the cold air outside the case and let the warmer air out of the case at the backside of the case (120mm fan).
Small problem, I have a dvdrw + floppy + fancontroller + reservoir that needs to fit in the remaining bays. Hope this works or i have to choose the following setup.
Drill out the top of the case to fit my rad. Bit more work but saves some space.
But radiator is cooled with hotter air from the case too the outside.
But the same setups will perform about the same, nothing to make me worry about. I already have a good caseflow (2*120mm + 4*80mm and 2*120mm at rads)
I think i'll go with the rad at top. :)
Delerious did you do that custom work at the top with the drive bays and such? If so, it looks completely professional.. amazing work.
Thx!Quote:
Originally Posted by MaxxxRacer
Yah i cut the drive bays down as it extended from the bottom to the top. Then built that shelf and flush riveted it in. Pretty simple, and i did it all by myself :D
I was quite proud of myself when i finished it.
Nice clean job. Well done.:toast:Quote:
Originally Posted by Delirious
But after understanding I definately agree with below :down: - Very NICE :D :up:
Originally Posted by Hardass
Getting my 'BsmtPc' Revision 3.1415926... ready. Just gotta hack out the bottom for better air flow and put the wheels back on :D
PC-V1000
PA-160 + storm + mcp655 + OCZ 600 PSU.
Drives will sit on left, taking floppy bay and using it for now, then some dremel work and riveting to take one of the HD mounts I removed and put it up there. Think there will be enough airflow for the drives. No window since this is for HTPC and no one will see it after I'm done :shrug: And I am making this another cooling system that can be removed w/o disassembly, just unplug and detach Res and Block, then pull the whole thing out :D
http://www.xtremesystems.org/forums/...1&d=1136769340
Very nice work mike, you think that rad would be sufficient for cooling a GPU too?
its the lian-li 7077
http://www.xtremesystems.com/modules...owcontent&id=6
wow great workmanship on that shelf. I wish i had those kind of skills..
Wich set is that from alphacool?Quote:
Originally Posted by 2fink
Look very nice and is real silent?
28c idle, 32c load, 37c case
Northwood 2.8C @ 3.5GHz
http://www.wtfhost.com//files/89/PICT0074small.jpg
http://www.wtfhost.com//files/89/PICT0010small.jpg
Trice.
That looks excellent. Add some uv dye uv cathodes and it'll loook kick ass:)
Trice.
Trice.
